While crown is all the way down in the normal position , turn the crown till the mode face (the bottom circle ) goes to TME.
press the A or B button (top button A , bottom B ) to select what city
where your time zone is to change . Example you are in eastern standard
then you would select NYC.
Now pull crown out to second click. with normal crown position is 0 this position would be 2 .
Use the A button to find proper city again to adjust time with . the city name should start flashing .
Now just use turn the crown to change digital time. When you change the digital time the analog time is also corrected.
Push crown back to 0 position .
and you are all set
