2005 Chevrolet Colorado Logo
Posted on Oct 19, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When should the serpentine belt be changed I have 64,000 on my 2005 colorado 5cyl
Anonymous
Level 2:
New Friend:
  • Expert 85 Answers
  • Posted on Oct 19, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
85
Questions
0
Helped
10152
Points
147
Only when you see cracks
2006 Chevy Colorado. I think my timing jumped. I went to start then I heard something popped from drive on the side under the hood. I notice the crankshaft sensor was not connected.
Question edited for clarity.
Question moved the Colorado sub-category.
I wonder is you picked something up and the serpentine belt whipped the stick or whatever and disconnected the crankshaft position sensor. Can you reconnect it and start the vehicle?
Can i run bosch platinum ir spark plugs in my 2006 chevy colorado 3.7l 5cyl?
you could.and they last a long time .i would use ac delco though.
Colorado speedometer reads high according to GPS
Find one of those radar displays that sit on the roadside and tell you how fast you're going. Most likely your GPS is the one that's off, because it has to average and estimate your speed, wheras the vehicle's speedometer should be good from the factory.
2helpful
How much transmission fluid does my 2005 chevy colorado w/ a 3.5L 5cyl w/ an automatic trans take when removing the pan and replacing the filter.
start by adding four quarts, then start engine and put thru gears and then back to park and recheck and add as needed,just keep repeating process untill full,make sure you look on dip stick ,it will tell you what kind of transmission fluid to use.
2answers
I am looking at a 2004 colorado with 3.5 5 cyl. engine with 115k. how is this vehicle performance and reliability
My 2004 Colorado 4x4 is at 91K and running better than I would have expected. It seemed to break in at 80K. Still getting 21 mpg. Haven't changed spark plugs yet. No major repairs have been needed except for the power steering pump I'm about to replace because of a squeal.
Intake manifold cover
remove oil cap steam an it should just lift off
Top Chevrolet Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a Chevrolet Expert? Answer questions, earn points and help others
