Question about Kenwood KAC-9104D Car Audio Amplifier
What does the red light mean i have had mine amp for a year use to run fine but now the subs dont work has power tried amp on otherr subs works fine
    New Friend:
  • 9 Answers
Red light is protection. subs r bad, if it works on other speakers and not yours.
Posted on Oct 20, 2010
SOURCE:
Amp worked fine one day and the next day i get nothing. the red light on the side is on but i dont get any sound. i took the subs that were wired on that amp and wired them on the other punch 800 i have...
did you check all fuses on amp and coming from battery power wire? also check the ground and rca cables connecting to the unit and make sure the remote wire (small blue wire) didnt come lose thats usualy a sign for the red light
Mar 26, 2011 | Rockford Fosgate Punch 800a2 Car Audio...
2 12" subs + 600W amp. Turn on, goes boom once, then red light
Is your gain all the way up? If it done this before, sounds like your over working the amp. Make sure your subs ohm load is capable with the amp load to. If they are 1 ohm and your amp is only 2 ohm stable, it would beat for a lil bit then go into protection mode to. Check your wires too.
May 13, 2010 | Insignia 600W Bridgeable Amplifier with...
My subs don't bump to the beat, they just go THUMP THUMP THUMP...
It sounds like you need to ask for pro help mate, mybe the amp just needs setting properly, Is the amp on bypass for bass, or does the amp run the complete system
Jun 13, 2009 | Cadence TXA 750D High Power Mono Amplifier...
LED Light is on, but no sound from sub at all.. Have double backed on all wires but still nothing! HELP!!
if you change amps and it goes on protection the speakers are blown causing the amp to protect try changing speakers
Mar 24, 2008 | Car Audio & Video
Amplifier problems!!!
it sounds like your running your ohms to low, check to see what the amp can power and then read up online about ohms and your subs and how they should be wired
Oct 12, 2007 | Car Audio & Video
SUBWOOFER NOT WORKING?
if you have real old wires from the amp to the sub try getting new wires on it. check the little wires that go to the cone itself on the sub. sometimes they can manage to get pulled out of their terminals and make sure that thier touching the terminals on the correct spot
Sep 29, 2006 | JBL GT150 Car Subwoofer
Kenwood KAC-9104D Car Audio Amplifier Logo
385 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
