SOURCE: WUSB54GC cannot associate with access point
Hi ian90,
Since u r using a linksys products no need to worry..it will work..
In the right bottom corner of ur computerscreen u can see a green square box(linksys
wireless icon) right click on to the green box and click on "use windows Zero
configuration" after clicking on to that u can see a small computer with wireless waves in the right bottom corner,right click on to it click on connect to a wireless network..u can see ur SSId click to connect it...it will prompt for a network key..enter the key and confirm the key..it will connect for sure..hope it will work..if there is any issue just revert back as soon as possible..
SOURCE: reinstall wusb54gc adapter
Hi there! You can download the drivers nessessary to reinstall your adapter from the Linksys website. Here's you a link:
http://www.linksys.com/servlet/Satellite?c=L_CASupport_C2&childpagename=US%2FLayout&cid=1166859919492&packedargs=sku%3DWUSB54GC&pagename=Linksys%2FCommon%2FVisitorWrapper&lid=1949219492B01&displaypage=download#versiondetail
SOURCE: Need working Windows 7 driver for Linksys WUSB54G V.1.0 Adapter
This driver should work with Vista, and based on the FAQ it should work with 64-bit although it wasn't designed for the 64-bit OS.
http://downloads.linksysbycisco.com/downloads/WUSB54G_dr,0.exe
If the link doesn't work, let me know. I'll direct you to the download page to retrieve the driver.
SOURCE: unable to setup Linksys WUSB54GC wireless network adapter
The Linksys WUSB54GC isn't compatible with Windows Me, upgrade to XP or Vista.
Minimum Requirements
SOURCE: linksys wusb600n on windows 7
WUSB600N version 2 will work with Win 7 using the Win Vista drivers.
You may refer to this link for compatible devices that work with Win 7.
You may also use the Win 7 driver - Ver.3.1.0.1.0 (32-bit, 64-bit).
Here is the link for the instructions to manually install the drivers.
Hope this helps!
