Computers & Internet Logo
Posted on Oct 19, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to install globe broadband-prepaid to a laptop?
Anonymous
Level 2:
New Friend:
  • Expert 106 Answers
  • Posted on Oct 19, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
106
Questions
0
Helped
17647
Points
347
Please specify what type of prepaid broadband, is this USB tattoo stick? or 3g / WIMAX broadband?
  • For tattoo, you simply plug in the USB tattoo stick to your computer and it will install automatically
  • For 3G / Wimax, you simply plug modem into ethernet port using LAN cable
3helpful
2answers
Di ako makapagfb using myphone Q19i...paano po b dapat gawin para makakonekta ako gamit ko ung cp n un? ty.
APN Settings for Globe, Smart, Sun, WeRoam Cellular
The following settings are applicable to Smart, Globe and Sun Cellular for their APN settings (Access Point Name). The settings should work with majority of smartphones in the market.
Postpaid APN: internet.globe.com.ph
Prepaid APN: http.globe.com.ph
APN Settings for Smart Bro
Postpaid APN: smartbro
Prepaid APN: smartbro
APN Settings for Smart Buddy, Smart Gold
APN: internet
APN Settings for Sun Cellular
Prepaid
APN (static): minternet
Authentication: PAP
IP address: dynamic
Postpaid
APN (static): fbband or minternet
Authentication: PAP
IP address: dynamic
APN Settings for PLDT WeRoam
Postpaid: WEROAMPLANor internet
Note: If you’re using a variety of postpaid or prepaid SIM cards in one dongle, make sure to create a Setting Profile for each SIM card so it’s easier to set the APN when switching SIM cards.
Leave all other settings blank or as is.
1helpful
How to configure mms/gprs/wap to cherry m33
I can help u if u use The Globe network. GPRS Access Settings
APN (Access Point Name): internet.globe.com.ph (postpaid)
http.globe.com.ph (prepaid)
Homepage: http://www.globe.com.ph/globe.wmlc
Bearer: GPRS
Proxy Address: 203.177.42.214
Proxy Port: 9201
MMS Access Settings
APN: mms.globe.com.ph
Bearer: GPRS
MMS Center: http://192.40.100.22:10021/mmsc
Gateway Address: 192.40.100.20
Gateway Port: 9201
Apr 19, 2012 • Cell Phones
Problem is globe broadband bm622 WIMAX no power
hi
find link for bm622 router configuration
https://www.globe.com.ph/help/broadband/troubleshooting/huawei-bm622.html#gref
Cani change my usb broadband stick which is globe tattoo into a sun broadband
Yup! You can change it there is no problem. You can also install them both in your laptop if you want. Because there signal is coming from different IP's
Sep 19, 2011 • Cell Phones
3helpful
3answers
How can i open gprs to cherry mobile
sir!! how can i install java application with my cherry mobile T2
Sep 16, 2011 • Cell Phones
How we can connect to the internet using globe prepaid sim?
hi. use broadband modem or hand phone ( must support modem function )
TQ
1helpful
How do i use my nokia c3 as a modem to connect to the internet
Before you want to use handphone as modem, you need to know your service provider(ex maxis).
For maxis (example), it have many chosen for browse internet through pc using handphone as modem. First through hot ticket and second through normal prepaid. Actually i'm always using the normal prepaid. For this method, you need to change your sim card to broadband. dial *100# for menu. after it approve that your sim was change to broadband, then you need to chose amount for internet.(ex rm8 for one day). after all that was approve, then you can connect your handphone to pc or laptop. You can use Bluetooth or cable to connect. For me, i'm prepared using cable as long it have great speed.
Before that, you need to install pc suite for nokia to laptop/ pc that you use. If you don't know how to use pc suite, then use manual. after connect cable/btooth, you need confirmation from pc suite to get connected also.
then from that you can use user iterface that already in pc suite.
If you don't use pc suite, then you can use broadband dial up. Username and password will gived by your provider.
Create new connection using broadband and dial up. enter username and password, then you will connect to internet, For first using, it will need time around 1-2 minutes. thanks
2answers
Hard to catch a signal from internet i'm using a globe broadband.
Your location matters a lot with mobile broadband. Contact Globe and ask them if they have some booster or something, if not, then all you can do is adjust your location and find the place where your signal is a lot better.
hope this helps.
1helpful
My prepaid broadband didn't work..it needs windows32 driver
If your Windows OS is 64 Bit you can,t use it as you said ,your broadband.But i bet your problem is other.Usually if your broadband is from a USB then a driver is needed to set up your connection.But if is a cable connection you don,t need any.Post more clear any error messages.
Grand Canyon Tech
Grand Canyon Tech
