I have a Bosch Nexxt WTMC 3300 electric dryer. It blows cold air and won't dry the clothes well. What should I check? The lint traps and the lint/blower is clear.
You might consider checking to make sure your vent pipe and lint filter are clear if you have not already done so. These dryers are prone to lint build up where the lint filter is inserted and can this can impact drying. You can also remove the vent pipe where it connects to the dryer and see if it works better. If it does your vent pipe may need to be cleaned. Let me know if the suggestions help. .
Did you check this FIXYA LINK below? Appears to have lot's of answers!
Also I WATCHED the YOUTUBE video I recommended and NOTICED his DRIVE BELT is WAY too loose! Methinks THAT is why his dryer has problems!
Be SURE your belt is not to aged because they can STRETCH and then TRIP the "RESET SWITCH" he's talking about. Note the way his PULLEY shakes so violently... AND the action of the belt itself...
if its not heating at all, first check electrical and make sure your getting 220 to the dryer if you are more than likely its the heating elements, check them and replace if bad
this could be a faulty moisture sensor. try running the dryer in a timed dry mode and see what happens.also be sure to make sure all the duct work is free and clear and that the lint filter is clean
it probably means there is an airflow issue (not enough to cool the heating element) either coming into the drier or going out. I would probably check the lint trap and hose leaving the drier
with the dryer unplugged 220v is not fun
with a meter, and first disconnecting cables to each component and reconnecting them after the test is complete
check the continuity of the element, it may have burned out
check continuity of the thermostats on the heater housing and fan housing,
check the interior of the fan body for sox and lint
I have a Bosch Nexxt WTMC 3300 electric dryer. The dryer doesn't heat up. This is the second time this has happened over a one year period. The first time it happened, the technician reset the thermal cutoff, but said he saw no reason why it should have tripped. Can you tell me how to reset the thermal cutoff or offer another solution?
