Pull up 'My Computer' then click on 'Control Panel'. From the Control Panel, click on 'Printers and Faxes'. You will then see a list of Printers connected to the PC.
Delete pending print jobs to make sure that the correct document will be printed later and for you not to waste paper. Double click on the printer that you want to use, and a window will appear showing you a list of pending print jobs. Simply click on 'Cancel All Documents' from the 'Printer Menu'.
After you have deleted all pending print jobs, right click again on the printer icon and choose 'Use Printer Online'.
Try printing a test file, if it doesn't work the first time, reboot the PC.
***If you need any technical help on printer then you can reach at here
Does the printer show any message on it's display ?
Most common problem with these printers is the driver setting (mostly media type/weight) conflicting with the settings made via the front panel menu's.
I would see what kind of data is being sent to the printer. If the spooler is trying to send some data to the printer that is outside of its limits, even a page break missing, it will do this. Also see how much data it is trying to send to the printer. If it overwhelms the printer, it will just give up until the spooler stops sending requests.
Make sure printer is powered on USB or other cable is connected to pc, then open the printer panle and double click on the printer you use. on the file menu make sure there is not a check mark on printer online, offline
hi
It is a request that please tell ur operating system as well to us so tht we are able to help u in a better way....
if your printer goes offline, then click on start> control panel> (in case you have XP)printers & faxes,(vista) printers> there u will find some printer icons> identify your printer & if it is off line then right clicki on it and select "use printer on line"....if it doesn't come online then go to start>
run> type in "services.msc"> a list will open> find "print spooler"> restart it by right
clicking on it. then go back to the printerv icon & check if it shows 0,ready. if it does
then try print. it will work....please let me know
To get back online of your printer, go to Control Panel and Select Printer & Faxes then OPEN. A list of Printer is on the browser, point the printer with your mouse then right click on your Printer HP OfficeJet to select Printer Offline and click it to go back Printer Online. Good luck!
- go to printers folder then check the status of your printer - if it is offline, right click the icon and select use printer online...
- check if there is pending documents becuase printer wont print if there is pending document in queue- to clear the pending docs. right click the icon and select cancel pending document
- printer OJ 5610 icon should be in ready status, no pending documents, and the icon has a checkmark as as default printer...
