Motorcycles Logo
Posted on Oct 19, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Headlights wont turn on - Ninja 250R kawasaki Motorcycles
Steve
Level 2:
Novelist:
  • Expert 113 Answers
  • Posted on Oct 19, 2010
Steve
Expert
Level 2:
Novelist:
Answers
113
Questions
0
Helped
51880
Points
334
Hi, check the fuse for the headlight after shutting off your motorcycle.
There is usually a fuse box under or just near the seat area. Sometimes it is located adjacent to the motorcycle battery. Check your user manual for the fuses location.
If that fuse is OK, remove the headlight element and remove the headlight halogen lamp by gently removing the wiring plug and rotating the halogen lamp that is inside, so you can inspect it for damage. A blown halogen lamp is usually indicated by a white or dark spot inside the glass lamp.
If you have a multimeter set it to Ohms and see if you can get a circuit thru the pins on the rear of halogen lamp before re-installing the lamp. There will be 3 pins - one is a common, one is the low beam, and the other is high beam. You should get continuity using ohms thru each separate pin to the common pin.
Make sure you remove any greasy spots on the halogen lamp before you put it back, as this causes hot spots on the glass and is a common cause of early failures of halogen lamps.
If you are comfortable measuring 12 volts DC with a meter, check that you have 12 volts DC at each pin on the harness which connects to the halogen lamp. Your ignition key will need to be turned on so that indicators and horn etc are all powered up. You normally shouldn't have to have your engine running to check power to your headlight, but it is possible that you may need to do so.
There will be 12 volts on 1 pin only and when you change to high beam that pin will then go dead and the other pin will then have 12 volts DC.
There is also a small chance your headlight relay is bad or has a loose connection. If you know what you are doing it should be easy to locate the headlight relay, otherwise take it to a reputable auto electrician or motorcycle repair shop.
Cheers,Steve PS Please vote for my answer or give me a testimonial if I have helped.
How to fix non working headlights
First check your fuses. If ok. Turn your headlight switch and see if rear parking lights turn on. If they do more than likely your headlight switch is not your problem. If running lights dont come on, check your headlight switch operation..
Sounds like a bad headlight switch.
Lights wont turn on a 99 silverado
Did you check for power in and out of the headlight switch ?
You should have power on the red and orange wires going into the switch and yellow going out to the dimmer switch.
My lights gages in my car car wont turn on when i have my headlights on
Are sure the dash dimmer control isn't turned off at the headlight switch?
1helpful
Headlights wont work properly
Sounds like you have a problem in your headlight switch. As far as them staying on sometimes when you shut the car off are you referring to daytime running lamps or the regular headlights? If it's daytime running lamps that like to stay on and your headlights do not like to turn on then there could be a combination of headlight switch and daytime running lamp relay.
It is possible the relay gets the signal from the headlight switch as well, since they generally turn off when you turn your headlights on.
1helpful
After turning ignition, only parking lights work. low beam headlights were replaced recently. parking lights wont even turn off. headlights
I had an S-70 with the same problem what happens is the headlight switch tabs that hol it together broke and the switch was slightly separated and connection was not there for the headlights and also check the high beam see if headlights come on i dont think it is a relay or fuse??? proballally the headlight switch and easy to replace you even can use one from an 850 model
The sound system was causing to much of an unpredictable power usage on the headlights and the fuse has blown as a safety precaution.
Have to get rid of the "RIGGED START WIRE"
and You May have Burned up the HEADLIGHT SWITCH
Top kawasaki Experts
Arnie Burke
Arnie Burke
Sean Wright
Sean Wright
Bob G
Are you a kawasaki Expert? Answer questions, earn points and help others
