Sharp XG-E3500 Multimedia Projector Logo
Posted on Oct 18, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need to reset lamp displayon sharp xg-e3500u - Sharp XG-E3500 Multimedia Projector
Anonymous
Level 3:
  • Master 8,197 Answers
  • Posted on Oct 18, 2010
Anonymous
Master
Level 3:
Answers
8197
Questions
7
Helped
3072755
Points
27242
To reset the timer go to the link below. It has the instructions.
http://unitedvisual.com/Pdf/SharpxgeCounter_Reset.pdf
Good Luck please rate 4 thumbs up and please leave a testimonial
I replaced the lamp in my Sharp XG-E3500U and there is lines in the picture now. How do I solve this problem?
mostly, this is caused by a default of the lcd screen inside, if so, you must replace it, if your model is using 3 lcd screen, open the cover, disconnnect one of them , run the projector, if you don't see lines, power off, reconnect it and disconnect the second, till you see the lines, so you can localise the default one. you also can try to check the lcd screen connector, disconnect, clean, reconnect
I have a Sharp Projector model XG-E3000U that won't power on. Nothing happens at all when you turn it on. No lights, no fan, nothing. I opened it up and checked the fuse and that's good. Is there a reset...
the powersupply is failed
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Installation projector sharp xg-e690u
Unplu the unit
Locate the user service screw, the lamp door should be underneath the projector.
open the lamp door
the lamp is removed by undoing 2 or 3 screws and pulling out with the handle.
a genuine replacement lamp with cage will mean you won't have to worry about wiring the lamp.
put new one in push connectors in firmly
do up the 2 or 3 lamp screws close the lamp door and screw up
reset procedure usually plug in power while holding down up, left and power and the lamp will be reset.
Hope this helps you
Good luck
Hope this helps
Sharp xg-e850u projector owners manual
I've searched all over...heh, I've got TONS of Sharp service manuals but *not* yours...I did find, however, the xg-e650 manuals on manualsparadise.com. Sharp units, a lot of times, are very similar in architecture, functions, parts, etc. For example, practically any Sharp remote will work on your projector...BTW, the lamp you need is a BQC-XGE850U/1 and sells for $292-389 dollars.http://reviews.cnet.com/peripheral-accessories/sharp-projector-lamp/4505-8309_7-31382143.html?tag=mncol;lst
2answers
The projector was at "change the Lamp" one of our staff just kept restarting the projector. I changed the lamp with a new one but can't get it to come on. I know that some Sharps will not restart if over...
I habe one of those
The probelem is you must use the exact same lamp model otherwise it wont run because of auto overload prevention
chek if you have the right sort of lamp,
fire the idiot what broke it,
find the manual- any codes/ instructions you need will be in it
1helpful
I have a Sharp LCD Projector, Model #XG-E650UB & it won't power up.
are there any leds lit? if not, it may be the bimetal circuit breaker. if the unit overheats, the breaker trips to cut the heat source, and needs to be reset manually. unfortunately, the top needs to be removed. it's located on top of the lamp housing (red button). if it's not tripped and still no power, you need to replace the power supply.
2answers
Large dot in the middle of the projected display
there is a burned-in spot on the polerizer light filter for the blue lcd. it makes sure the light is blue coming through, that's why it is black on a blue screen, and yellow when the red and green are the only light showing through. it needs to be replaced. pat # PFiLW0213CEZZ.
3helpful
Sharp xg-nv3xe lamptimer reset
hod down enter, menu, and down arrow, then press power.
SHARP XG-P25X PROJECTOR PROJECTOR RUNNING THEN IT IS AUTOLOG OFF AFTER 2MIN. WHEN PROJECTOR IS RUNNING ITS SHOW GREEN LED AFTER LOG OFF IT IS SHOW RED LED ON LAMP AND POWER LED
either the lamp hours are close to or exceeding 1400 hrs and the lamp needs replacing, or the ballast is starting to fail. with the projector on, check the lamphours in the menu. after you replace the lamp (if it needs it), reset the lamp timer by holding down the down arrow, right arrow, and enter buttons, then press power.
Having problems with my sharp notevision XG-C40XE
Your lamp is not lighting up most likely. Try removing the lamp assembly and clean the contacts. If that does not work then you will probably need to replace the lamp. Also try resetting the timers. Refer to you owner's manual for info on how.
Top Sharp Office Equipment & Supplies Experts
k24674
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
