Some times the tape becomes to tight and the pick up reels cannot adjust them selves? I had the same problem with this one tape that would not load and was ejected immediately. What worked for me was to pull out that particular tape and unlocked the reel by using a small screw driver on the square notch on the back of the cassette. It is a small square hole in the middle back of the cassette, move that little notch upwards and then with your finger try to turn the right reel clockwise, just enough to loosen the tape inside the cassette. When i loaded the tape back into the camcorder it worked perfect, don't know if this might help you but worth a try. The camcorder has to be able to work the tape into it's proper alignment and if the tape is to tight it will eject it.
Thats is because the servo mechanism chip do not detect the cassette,
when its in the housing could be a sensor or the cassette in switch or mechanism its self (missalignement.)
hope that will help you
regards alan.
