Pinch Roller errors mean that the location of one or more of the pinch rollers is not correct. To fix the problem, simply try raising the pinch roller levers and move the pinch rollers to their proper positions above the grit rollers.
Reposition the material to match position with new adjustment. If you still get the error, then is the left grip roller that is not centered over the girt roller.
Also Ensure that you are setting the base point immediately to the right of the crop mark (it should have a rectangle on it).
If you are still getting this error you will need to ensure that the roller sensor magnets are still connected. Right behind the roller is a small rectangular magnet. After years of use this
magnet missing the magnet is missing the unit will need to go in for repair.
In that case call the Roland support number found on the user manual.
