Lucent Definity 8403 Corded Phone Logo
Posted on Dec 14, 2017
We just recently changed phone and internet provider. Now the phone line lights do not light up when a line is in use they flash slowly. Also when a line is in use another person can pick up the phone and listen to the conversation. Please help. I have the manual but it doesn't state anything about my problems.
1 Related Answer
Anonymous
  • Posted on Nov 13, 2008
SOURCE: Lucent partner 18 D phone no sound when I pick up the receiver
The plug going into the phone was not secure. Once it was fully plugged in it was operational. I was making a big problem out of a little one. I thought in cleaning the phone without unplugging it first I somehow messed with the programming. I was wrong. Thanks for trying to help.
1helpful
What happen when a adsl line work with a phone but not with a router
The phone line does two jobs. Voice phone which is what it was originally used for and ADSL modem which works at a high audio frequency.
Somewhere between the phone socket and the modem should be a filter splitter. One part goes to the phone and the other to the router. Make sure you have that.
The modem will have a power light and several additional lights. Assuming the power light is on we are interested in two of them; The ADSL light and the Internet light. When you switch the modem on you should first see the power light flash then go solid. Then the ADSL light will flash and then this should go solid. If this light does not come on then you have not plugged the phone wire in properly. If this light just keeps flashing slowly then the modem can't see an ADSL signal on the phone line. If you have a spare router you could try it and see if the ADSL light goes solid on that.
If the ADSL light is fine then the modem has locked onto the signal on the phone line, sync'ed. If not then this is the problem you must solve. Ask your ISP if service is set on your line.
The next light is the Internet light, this maybe a symbol like an i or a world. This light will begin flashing then go solid. It will flash with Internet traffic. This means you have Internet, as far as the modem is concerned. If this light does not stay on then your ADSL account name and password maybe wrong. You can correct this but that's a different question you need to ask.
I moved. magic jack says no line when hooked back up
  • Is everything turned on?
  • Is the blue light, inside your Magic Jack dongle, on? (Note that the Magic Jack Plus should have a flashing red and green led as well.) If you use the older model you might need to connect it through a powered hub to ensure the device receives enough power to operate properly?
  • If this is a new installation, is your internet service and computer capable of handling the requirements placed upon them by Magic Jack?
  • Do all your connecting cables appear to be firmly attached?
  • Are you watching Netflix, downloading or streaming files at the same time you are attempting to place a call?
  • If you are using the Magic Jack Plus, does the system report Error 3002?
Next, you should ask yourself what recent changes you have made to the computer/Magic Jack software? What recent upgrades have you performed to your hardware? Could this have effected the performance of your Magic Jack?
If your difficulties persist, it is time to divide and conquer. Google a 'you tube' link and watch the video. If you cannot connect to the internet, consult your internet provider for assistance. If the video is choppy, the internet connection might be too slow or bogged down. Perhaps your computer is too slow or requires maintenance. If you cannot hear sound, you might be experiencing problems with your soundcard or sound drivers. You should check Control Panel/Sound and ensure that 'USB internet phone by Tigerjet' is installed.
If the video ran correctly, the next step would be to test your handset and phone cord at another location.
If you prove the handset/phone cord to be correct, you have pinpointed your fault to either the Magic Jack or its software. Contact online support for Magic Jack.
What does it mean when the far ethernet light is flashing fast and the cable light is flashing slowly. the power light and on line light are on steady. I have internet access when connected direct to...
Try this:
  1. Disconnect power to modem
  2. Disconnect power to router
  3. Shut down PC
  4. Wait 2-3 minutes
  5. Reconnect power to modem, and wait ~ 1 minute
  6. Reconnect power to router, and wait 30-60 sec.
  7. Reboot PC
  8. Try to reconnect to internet...
2answers
How do I set phone to ring at my extention?
Partner, all releases.
Examples
Receptionist Call Routing. If you want calls to be answered by the receptionist first, set the lines at the receptionist’s extension to Immediate Ring and the lines at the users’ extensions to No Ring. (This is the factory setting)
Receptionist Backup. If you want all calls on a line to ring directly at users’ extensions -with the receptionist providing backup -set the line at the users’ extensions to Immediate Ring. Then set the line (or lines) at the receptionist’s extension to Delayed Ring. An incoming call that is not answered by a user within 20 seconds will also ring at the receptionist’s extension.
Programming
To change the way outside lines or pools ring at an extension:
  1. Press [ Feature ] [ 0 ] [ 0 ] [ System Program ] [ System Program ] [ Central Tel Program ].
  2. Enter the number of the extension to be programmed for Line Ringing. The green lights next to the line or pool buttons on the phone show the current Line Ringing settings for all lines assigned to the extension. (If a line is not assigned to a button, the green light next to the button is off.) The following ringing options can be shown by the green light next to the line button.
    • Immediate Ring - on steady
    • Delayed Ring - flashes slowly
    • No Ring - flutters quickly
  3. To change Line Ringing for any line, press the line or pool button until the button light shows the correct setting (the setting for the currently selected line or pool also appears on the display).
  4. Continue programming or exit programming mode.
I have the same problem. The Sync DSL light keeps on flashing. According to the 3Com and Singtel, they both blame one another. From my understanding, the modem is not receiving and internet signal at all....
Yes, when the sync light flashes it meand there is no sync to the DSLAM located at the exchange. This is usually down to either bad wiring (too much line noise) or the provider not having set the line up.
Have you tried connecting the router to the master socket in the house with no other equipment connected - phones faxes modems etc? they can cause problems sometimes.
2answers
Can't turn off the blinking message waiting light
Unplug the phone from power for about ten minutes and see if that resets it..i'm not sure if that uses and adaptor for power... but be aware it also gets power from the phone line as well... so unplug that too.
Robert
Please take a moment to rate this solution.. thanks
3helpful
Stop ringing at certian phones when outside calls come in.
http://dstech1.com/programming-line-ringing/
Examples
Receptionist Call Routing. If you want calls to be answered by the receptionist first, set the lines at the receptionist's extension to Immediate Ring and the lines at the users' extensions to No Ring. (This is the factory setting)
Receptionist Backup. If you want all calls on a line to ring directly at users' extensions -with the receptionist providing backup -set the line at the users' extensions to Immediate Ring. Then set the line (or lines) at the receptionist's extension to Delayed Ring. An incoming call that is not answered by a user within 20 seconds will also ring at the receptionist's extension.
Programming
3helpful
Intermittent ADSL connection
The DSL light blinking or going out indicates that the DSL modem is loosing sync. This is usually caused by noise on the line. When you get the DSL service you should be given filters to put on all of your phones so that the phones will not interfere with the DSL signal. Those filters need to be attached to anything connected to the phone line that has the DSL on it except for the DSL modem. Other than that the problem could be on the service providers end, something outside your home, or the DSL modem going out. I would suggest that you verify everything is filtered, then contact your service provider so they can run test on your DSL line.
3answers
Belkin f5d7633-4 wireless g modem/router
when you upgraded did any settings from your isp change like passwords or usenames that your router may not be registering at your isp's server, or the line speed that you are now getting is not suported by the router.
type 192.168.2.1 in your web browser and check the connection settings.
5helpful
4answers
My ethernet light is blinking
Make sure you have internet. The ethernet light is blinking because what ever u have plugged into it is talking to the modem. The modem will then take that request and ask for it on the DSL/internet line. Make sure the DSL light is steady on and the internet light is on or flashing with activity.
Top Lucent Lands Phones Experts
vince
ADMIN Andrew
ADMIN Andrew
Are you a Lucent Lands Phone Expert? Answer questions, earn points and help others
