Maxon SP-100G (4 Channels) 2-Way Radio Logo
Posted on Jun 04, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Reprogramming a Maxon SP 100G?
Is it possible to reprogram a Maxon SP 100G for frequencies other than GMRS?
if this can be done can you please contact me @ [email protected] with a price?
-Asa
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jun 09, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
618
Points
Could you tell me if it is possible to reprogram the maxon sl30 it is currently on easiwave thanks best regards dennis
Anonymous
Level 2:
Sergeant:
  • Expert 250 Answers
  • Posted on Jun 04, 2008
Anonymous
Expert
Level 2:
Sergeant:
Answers
250
Questions
0
Helped
83970
Points
521
Hello codeencrypt,
THE SP100G is essentially the same radio as the SP100U UHF business band unit that Maxon made at the same time, just pre-programmed for GMRS. I believe there is a programming kit for this radio (Model number: SPK400C) which may still be available for purchase from Maxon directly. Otherwise, your best bet is going to be contacting your local Maxon dealer to see if they have the capability to program he radio.
Best regards,
Ken
"Go Ahead. Use Us."
1helpful
2answers
Can i catch outdoor frequencies like polce etc?
It is possible if you have a radio programmed to police or emergency frequencies, or better yet, a scanner. Your local electonrics store should be able to help you with this.
Best regards.
Can two different style motorola 2 way radios be changed to same frequency
Hi Kate,
The short answer to your question is: no, or "not readily". Here's why:
The Motorola 4900 radio operates in the FRS (family radio service) and GMRS (general mobile radio service) in the UHF band. This radio will work with any other FRS / GMRS band radios (no reprogramming of transmit and or receive frequencies is possible for these radios). The trick is that the numbering of the channels may differ from brand to brand ie: Ch1 on your Motorola may not necessarily be Ch1 on a Midland radio or other brand. A complete list of the frequencies and channel assignments for FRS /GMRS can be found on Pg. 17 of the manual. It is important to note that without a valid GMRS license, you are prohibited from transmitting on the GMRS only channels (Ch 15 through Ch 22). The combination GMRS/FRS channels (Ch1 through Ch7) and the FRS only channels (Ch8 through Ch14) are for individuals and family members that do not have valid GMRS licenses. If this is you, you should limit your transmissions to Ch1 through Ch14 only, as FRS does not require a license in the US. Unlicensed use of GMRS only Ch15 through Ch22 can result in fines and imprisonment if caught by the FCC.
Further complicating the issue are the so called "privacy tones". This is simply a very low or "sub-audible" frequency that is sent whenever transmitting. Motorola calls these "Interference Eliminator Codes". When another radio receiver is set to listen for a particular privacy tone, it stays silent until a transmission with the exact same privacy tone is detected. Again, these tones are listed in no particular order, but are generally listed as 1, 2, 3, etc. or a, b, c, etc. instead of the actual frequency in hertz. You can selectively set your radio to transmit & receive one of the 38 codes or, set the code to "0" to communicate with radio that do not offer these privacy codes - or does not use the same frequencies for these codes. You can read more on Motorola's codes on Pg. 19 of the manual.
The Motorola CP200 radio on the other hand is a commercial radio, and requires computer programming with Motorola software. The CP200 is offered as both Low & High sub-banded VHF and Low, Mid & High sub-banded UHF radios. You would need to have a CP200 that is designed to accept the Mid UHF band (438Mhz - 470Mhz) frequencies in order to program the 462Mhz & 467Mhz FRS / GMRS frequencies into it. The final obstacle would be what is called "FCC Type Acceptance". The CP200 is probably NOT Type Accepted for transmitting FRS/GMRS frequencies, and as such the Motorola dealer doing the programing might balk at putting them in. You can read a spec sheet on the CP200 here.
I hope this helps & good luck!
Can motorola talkabout T5720 FRS/GMRS talk with Motorola GP338 UHF?
Your GP338 would need to be reprogrammed to one or more of the frequencies available in the T5720. If you are using the interference code eliminator, it would also need to be programmed into the GP338. Take your GP338 to your local Motorola dealer for reprogramming.
Here is a link to the user guide for the T5720, where you will find a list of frequencies: http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T56XX_57XX_User_Manual_E.pdf See page 19.
Best regards.
1helpful
HOW DO I GET ONLY THE CHANNELS I WANT
You can use the LOCKOUT key to temporarily bypass unwanted channels, or you can delete the unwanted frequencies by reprogramming their channels with "0.0" I hope this helps, and please contact us again if you have have other scanner questions.
Maxon sl100
Hello baba_zam,
The Maxon SL100 can be programmed but doing so requires a programming kit including software and a specialized cable. Unless you are going to be reprogramming a lot of units regularly, you are going to be best served by taking the unit into your local Maxon dealer and paying them to reprogram it for you.
Best Regards,
Ken
"Go Ahead. Use Us."
Communications
Yes, but depends on the configuration/setup and programming/frequency assignation of the MTS2000.
To my knowledge, the UHF version of the Motorola MTS2000 are designed to operate either in the 403~470Mhz or the 450~512 or 520MHz band.
On the other hand, Motorola TalkAbout Radio are design limited to operate in the FRS band which is 462.5625~462.7250MHZ and/or the GMRS band which is 462.550~467.725.
So technically, both the MTS2000 and the FRS/GMRS share some frequencies. What needs to be done is to re-program the frequency allocation of the MTS2000 into its channels to match the TalkAbouts frequencies. The other way around is not possible. TalkAbouts frequency assignments can not be reprogrammed/changed. Below are typical TalkAbout Channels/Frequencies.de11c4e.jpg
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Locked Out
First and formost, What you will need to do, is contact Sprint/Nextel customer care, to get what is called the PUK codes, if you have your phone on a Business/Personal/Corp account, you WILL need to have verification. This WILL NOT force you to lose your contacts, also just a friendly tip, Reprogramming the phone will NOT make you lose your contacts.....ever.
The only thing that could possible to this, is if you do a master reset, through the phone security options * if you have a older Update version *.
Let me know how it goes,
Thanks
Justin
Please Rate Me.
6helpful
3answers
Maxon GMRS-21a
I Just had Batteries Plus rebuild mine with 600mah cells $ 23 each.
Maxon MCB 10 A
I'm not sure about your particular model but many CB radios use the microphone push-to-talk switch to kill the speaker while the radio is transmitting. If you don't have the correct microphone or if the cord has a broken wire it can cause the radio to have no sound. Another possibility is that the speaker is bad. There is probably an external speaker jack on the back of the radio. You could try plugging a different speaker or even an earphone in the jack to see if you get sound there.
Top Maxon Radio Communications Experts
eradiostore
eradiostore
Johnny 1000
Are you a Maxon Radio Communication Expert? Answer questions, earn points and help others
