Nokia N70 Cellular Phone Logo
Posted on Oct 18, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My N70 shows white display but other activities it works properly. ones you disconnect the display and again reconnect the same, the display will work for 2 to 3 days and again same problem occurs. please help me for this problem.
Anonymous
Level 2:
Habit-Forming:
  • Expert 92 Answers
  • Posted on Oct 18, 2010
Anonymous
Expert
Level 2:
Habit-Forming:
Answers
92
Questions
0
Helped
17324
Points
274
First format your phone by using this code
first switch of your phone then press the star(*) three(3) and call button holding these button and switch on the screen displays blank white screen for sometimes and then on .
after this process the problem continuous , please check and change your mobile display with the help of an expert mechanic ,
most of the n70 users facing these problem
thank you
please rate me if my opinion helps you
11helpful
3answers
My Nokia N70 shows white screen only when turned on and will not respond to any input ..how can I reboot the system..my PC shows no connection and will not recognise my N70
hi,
there are two kinds of white screen in n70 ,the first one is because of damage LCD (glass screen) ,defective display driver (small chips that makes the display works) and the other one is corrupted software...in damage lcd the phone will detected by computer because its software is still working...so ,the problem of your N70 im sure is the second one ,corrupted software....your phone needs to reprogram,and need to go to a nokia care center to fix you problem...i hope ,i will help you ,thanks for trusting fixya...
2helpful
N70 WHITE LCD BUT PHONE IS WORKING PROPERLY
YOU SAID WHITE SCREEN AND NO DISPLAY! IF POSSIBLE REMOVE LCD CONNECTOR STRIP CLEAN IT WITH COTTON AND SEE TO IT THAT THERE IS DAMAGE TO CONTACTS OF LCD STRIP.IF THERE VISIBLE DAMAGE MEANS WARN OUT CARBON CONTACTS,CUT 0.1 mm AND CONNECT IT AGAIN. IT MUST WORK.ALL THE BEST.
14helpful
N70 DISPLAY IS BLANK/WHITE
Its a display IC fault.heres the screenshot..replace this two crystal IC for display.9323da0.jpg
9helpful
E1 F5 error message when try to activate the self clean
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
1helpful
N70 White display
its about display connector.follow display wires & try to fix the connectors
3helpful
4answers
Nokia N70 Screen gets white blank
check your battery! i think you are using duplicate battery! put original battery to your mobile! again the problem came mean install new software and format your mobile
57helpful
6answers
Display problem
i also have the same problem...white screen display
5helpful
4answers
N70 blanking(all display white )
It looks that your N70 has a booting problem. Your phone wasn't booting. Usually the boot IC goes bad and needs t be replaced. You have complicated your problem by changing the glass IC's. This surely wasn't your problem. I'm not sure if you have replaced them correctly though. If you have a digital multimeter than check your phone across the battery terminals. Keep the meter on 'Continuity' which also shows a 'Diode' symbol and check ur phone .Between +ve to grnd, one side, the meter shd show around 370 ohms and reversing the polarity of the meter across the same terminals of the phone the meter shd show a reading similar to a capacitor discharge action towards infinity. Now if these readings do not show, then the phone has a 'shorting' somewhere. I suggest u take your phone to a technician he may be in a position to kick start it back to life.....................
2helpful
3answers
My n70 had white display pls help me sir
full charge the set..it might show the display then..but after some hours it might become white again..i am also searching for a solution of this problem!
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
