I have an hbm 730 I have not used for some time now I want to give it to my wife but I forgot the password. Is there some way to get around this problem?I have an hbm 730 I have not used for some time now I want to give it to my wife but I forgot the password. Is there some way to get around this problem?
You can't post conmments that contain an email address.
To put your headset in paring mode, first turn it off. Then, press and hold the PWR/END button until the indicator led is solid lit (some 5 seconds). Now, make your phone's bluetooth software to search for devices. Select 'LG HBM-730' from the list. If a passkey (or PIN, or pairing code) is requested, enter '0000' (four zeros).
Hope it works for you
Turn it on by holding the power button for four seconds, Then go to your phones bluetooth setup screen, search for new devices, and pair it. The blue led on the HBM-760 will turn solid blue during pairing. It is always discoverable. The default passkey is 0000. Hope this helps.
Good luck and please rate 4 thumbs for the free answer
my teknic bluetooth told me dat i needed a passcode to pair with my phone but i just dismissed the notice and it worked for me, what i done was searched for devices using my bluetooth, found the phone and it paited up, but when i searched using my phone i needed a pass code,
sorry if ive been no help to ye
Try 9999.Else the passcode has been changed earlier or the piece is
malfunctioning.you did nothing wrong so far,since the headset is being
detected.If the headset still does not pair with the phone,then have to
check it with the vendor.Good luck,Please do post comments and results.
I have the same model, and if you turn it on and the light stays on, usually after a flash and about 10 seconds, your headset isn't paired with your phone. You need to re-pair it with your cell phone, the code is 0000. That should work.
same
i received the hbm 730 but no passcode
i received hbm 730 headset but no passcode
