Question about Kenmore 20.3 cu. ft. / 575 liter Upright Freezer 23024
The freezer is running, and the light is all coming on but it is not freezing the contents in the freezer?
  • Kenmore Master
  • 3,740 Answers
Hi and welcome to FixYa. I am Kelly
If your sure the compressor is running and it is not freezing then there has to be a system coolant leak.
Having said that there are a few things to check:
1. Is the compressor in fact running Y / N
a. Yes = coolant level problem or coolant system blockage
b. Not running = (Possibilites below)
1) PTC / Klixon Thermal overload failure
2) Run capacitor failure
3) Temp control failure
4) Automatic defrost thermostat or thermistor
5) Defrost timer or Adaptive defrost control failure (depending on model)
2. Is the compressor very hot to the touch or room temp?
a. VERY hot = unplug the unit for at least 30 minutes and then plug it back in.
b. ROOM temp = any of the above in 1b items 1) - 5)
3. Is the evaporator fan running?
a. Yes = Temp control is ok Defrost system is probably ok
b. No = same as 2b
With a model number I could pass on a few additional things to do. For the moment use the above.
Thanks for choosing FixYa,
Kelly
Posted on Oct 18, 2010
  • 51 Answers
Is there frost on the back pannel in the freezer? if so there is a problem with the defrost heater. Could be several differant things like( thermostat,Defrost advance,timer, mother board... ect). need more info as to the problem.
SOURCE:
Idylis 5.0 cu ft chest freezer: why is the outside of my new freezer hot to the touch, while the inside is freezing?
if new and a 5 ltr
check thermostat setting
it takes some time to freeze up unit and contents
motor will run a bit longer then normal
then should kick in on and off with the thermostat
Sep 13, 2016 | Freezers
Hello,I defrosted my electrolux chest freezer and now problem is power is on but not freezing,alarm light keeps coming and keeps bleeping every 2 minutes and goes off and on
Is the compressor running? if it is running, but there is no cooling, it is time to buy a new freezer.
If the compressor is NOT running, I would suspect the compressor start relay.
How did you defrost it?
Jun 09, 2016 | Electrolux Frigidaire 14.8 cu. ft. Chest...
Why does my freezer not freeze?
Sound like a typical low freon Issue. Check out our articular on recharging residential refrigerators and freezers
On Time Appliance
If it Helped follow us on our Google plus page.
On Time Appliance Google
Jun 29, 2015 | Freezers
Green light wont come on
Is unit running? Orange switch - is that the fast freeze switch? If on and running, green light faulty. If nothing happening, start with fuse, test the switch and make sure power is to the thermostat.
Apr 04, 2014 | Freezers
Sears model 253.9280212 UPRIGHT FREEZER NOT KEEPING FOOD COMPLETELY FROZEN. EVEN AFTER HALF OF CONTENTS HAVE BEEN REMOVED, REMAINING CONTENTS DO NOT COMPLETELY FREEZE. WHAT'S WRONG? HOW TO ID PROBLEM?...
make sure the unit is running and not shutting down to soon if it is change the cold control if unit is staying running the replace unit
May 06, 2010 | Freezers
Am I supposed to turn off the quick freeze once the deep freezer is cold?
http://www.mcappliance.com/document/MCCF5WBX.pdf
i read the entire manual and even type in the words "quick freeze" in pdf. find space and it is not in there.
heres the link read it for yourself
it only mentions green light and red light.
The “POWER” light (Green) indicates that the freezer is properly connected to the electrical power.
The “RUN” light (Red) will not illuminate when the unit is operating below freezing.
The “RUN” light will illuminate when the temperature inside the unit increases above freezing. Please
be advised that the “RUN” light may come on for a period of time when the lid is opened, when new
items are stored inside the unit or when the lid is forced open by irregular contents.
Do not call for service unless the “RUN” light has remained on for 6 hours or more. If this light stays
on continuously for a period of 6 hours, please contact our Customer Service Dept. to consult with a
representative at 888 775-0202 or visit our website to request warranty service at www.magicchefewave.
com.
Apr 02, 2010 | Magic Chef Chest Freezer MCCF5WBX
Does the light on the outside of freezer stay on . I bought a used freezer. It is a frigidaire commercial upright (frost free) Does the light on outside of freezer stay on all the time? I have no manual....
Normally there is a Green light showing that power is on
A Yellow one for fast freeze and a Red one for under temperature
The outer casing is well insulated from the inside otherwise the freezer motor would run none stop without cooling the contents so the temperature of the outside casing will reflect the room temperature not the intenal
Aug 21, 2009 | Frigidaire 20 cu. ft. / 566 liter Upright...
Kenmore 20.3 cu. ft. / 575 liter Upright Freezer 23024 Logo
392 people viewed this question
Top Kenmore Freezers Experts
AJMAL KHAN
Jay Finke
Jay Finke
geapptech
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
