Hi
To help troubleshoot a problem, Dell Dimension 5100 has four diagnostic lights labeled "1," "2," "3," "4" on the front panel. When the computer starts normally, the lights flash. After the computer starts, all four lights
lites solid green. The power button also
lites solid green. If the computer malfunctions, the color and sequence of the diagnostic lights as well as the power button helps identifies the problem.
First, disconnect the power cord and remove all connections (Keyboard, Network, Mouse etc) as well as optional
PCI Cards. Connect up the power cord (Monitor as well) and try powering the PC.
Check the diagnostic lights/system lights color and sequence and check the link below for more info (Assuming you have another system that can access internet)
Diagnostic Lights -
http://support.dell.com/support/edocs/systems/dim5100/en/sm/tshoot1.htm#wp1120147System Lights -
http://support.dell.com/support/edocs/systems/dim5100/en/sm/tshoot1.htm#wp1114432
Reply with lights color and sequence as well as any beep codes and I will respond at best effort.
Mike
