It will not turn on at all. LED red light is blinking
First try a hard reset. Just unplug the power cord for 4 hours or more; then try again.
If the reset does not help it means the problem is hardware
failure and not software. Therefore, you will need a tech who can
diagnose the electrical circuits. The short circuit conditions could
be in any location within the 8 or 10 sections of the tv.
Please Rate This !!
The exact same thing just happened on my 32" Acai television with the dvd player built-in. I'm going to turn it off now and unplug until tomorrow and hope for the best. Darn it!
The remote control can also control dvd and vcr. make shore it's on the tv seting. I'm sorry if this is something you have already tried.
SOURCE: power led blinks but no picture or sound
Had the same problem myself. Took some doing but I managed to find a service bulletin that I downloaded. The problem is with the siene module and all you need to do is unplug connector JP63A from the main board and your TV will work again.
Take the back off the TV (there are a lot of screws) and look on the left hand side of the main circuit board that is mounted in the center of the TV. You will see a small white connector that is labelled JP63A, simply unplug it. Plug the TV back in and let it reboot. That's it, should be able to watch immediately.
SOURCE: toshiba plasma 42hp95 tv will not turn on red led lights blinking
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also
ensure that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem with no receiver box
or dvd connected.
If that does not work, and you keep having a flashing
led on front of the TV, and tv turning off by itself after a while,
that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The
internal circuits are jammed because of electrostatic
charges accumulating on capacitors, or because of a wrong voltage read
by the main chip on your monitor controller board. this started the
protection circuit.
2 The protection circuit detected a wrong
voltage or abroken contact, identified an internal fault and kicked in
, startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults
that can occur are a blown capacitor on power board, a
convergence IC has blown, or a fault on Digital board.
Check also
the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you
can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
After a quick power failure (off/on) the unit will not turn back on. The DVD LED blinks with twwo or three fast blinks in a pattern.
1. I unpluged the unit for several minutes and tried holding the power button on. No response.
