Samsung LN-S2651D when i turn it on it will Play But after it plays for alittle while & i shut it off --it will not turn back on A few hours later it will turn on again--but again if i shut it then i have the same problem again--it won't turn back on
Tuner fault. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. http://electronicshelponline.blogspot.com/ Pull up older posts there.
Do flashlight test on unit. If you can see an image thruout screen the problem is with the tcon board. If no image then it is the inverter board/circuits.
Tries unplug,replug the tv back an hour later.The tv now,is resetting itself back to factory.Tv should work now.Not,than the power supply board,have problems.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Check with Samsung, this model should still be under the 3 year warranty. You are having a problem with the backlight power supply. You can look on the back of the unit for the manuf. date, if its less than 3 years then go to www.samsung.com and process the online service request form.
Have you check with the cable company to make sure they are broadcasting to you in HD ? It takes more bandwith so some cable companies will charge extra for it so you will have to check.
A lot of times it only pops the on board fuse, or if it has a transformer, then it often simply "Blows" the Primary windings and not too much happens on the secondary, If it is a switchmode well then you probably will have to replace the entire thing.
I lived with it for about six weeks, then took the back off the TV. Just now it seems to be fixed, but I don't know if it will last.
I disconnected the wire leading to the channel up/down, volume up/down and source board, turned on the tv, turned it back off, reconnected the cable, and everything seems fine now.
