Hello
If that did not work, let's try to force a reboot. If you have a leather cover on it, remove it. The battery charging circuits are controlled by the software as well. If the software isn't allowing the Kindle to accept a proper charge, it may cause the Kindle to malfunction too. Plug the Kindle into the charger for 10 minutes. After 10 minutes and while still plugged in, slide or press and hold the switch for one minute. Make sure you don't disconnect the power during this entire process. Allow 3 minutes afterward for the Kindle to reboot. If this doesn't correct the problem, let me know the approximate purchase date of your Kindle.
Many issues with your Kindle Touch, such as a frozen screen or issues with downloading content, can be solved by restarting your device.
1.Press and hold the Power button for a full 40 seconds.
After the first 6 to 8 seconds, the screen will go blank, which is normal. Continue holding the Power button.
2.After the 40 seconds, release the Power button.
The charge indicator light will turn on after a few seconds.
Did you forget the password used to unlock your Kindle? If so, you'll need to reset the device to gain access. By resetting, your Kindle will be restored to factory defaults, which means your registration information and content will be removed, and all settings will return to the defaults.
To reset a Kindle Fire 1st Generation:
1. From the lock screen, slide the Unlock Bar from right to left
2. Use the keypad to enter characters into the password/PIN field four times
3. You'll be prompted to reset your Kindle Fire. Tap "Ok reset"
To reset all other Kindle Fire models:
2. Use the keypad to enter characters into the password/PIN field five times.
3. When prompted to reset your Kindle Fire, tap "Reset"
To reset a Kindle 2nd Generation, Kindle Keyboard, or Kindle DX:
1. Slide and release the power switch to turn on the device or exit sleep mode
2. Enter "resetmykindle" in the password field and press the enter key on the key pad
3. Wait several minutes while your Kindle restarts
To reset a Kindle (5-way controller):
1. Press and release the power button to turn on the device or exit sleep mode
2. Select the keyboard key once on the password screen and enter "resetmykindle" in the password field, then select "Enter"
To reset a Kindle Touch or Kindle Paperwhite:
2. Tap the password field to bring up the onscreen keyboard
3. Enter "111222777" and select "OK"
If you don't remember your Parental Controls password, you can deregister your device instead of resetting, as long as you're connected to a wireless network. You'll need to redownload your content, but items that were transferred via USB will be kept. Here's what to do:
1. Visit the Manage Your Content and Devices (www.amazon.com/manageyourkindle) page on your computer
2. Select the "Manage Your Devices" link
3. Select "Deregister" to deregister your device from your account
Sync your Kindle, then register again.
If you need help with your Wi-Fi password, please contact your Internet Service Provider or router manufacturer.
My daughter forgot hers as well and Kindle support is the only place to get the right support regarding your specific model and directions for resetting your device.
If it is the Amazon.com account password then go online and change your password. If the device password then try the following:
Forgot my password
Slide and release the power button. The LED light that
surrounds the power button will display green for two seconds.
Shut down Kindle by sliding and holding the power button for
five seconds. The LED light will blink three times. Wait for the
screen to go blank, then release the power button.
Turn on the Kindle by sliding and releasing the power button.
If Kindle is still not working, you can perform a hard reset
by sliding and holding the power button for 15 seconds.
If Kindle is still unresponsive, try charging Kindle before trying to restart the device once again.
Make sure you have the latest software version available
installed on your Kindle. The latest version is available here: www.amazon.com/kindlesoftwareupdates
If you continue to experience problems, please contact us.
^ The above information, and much more is found on Amazon's kindle troubleshooting section. The link below will take you there in case you have any further problems.
Hello, Amazon recommends the following steps. As I'm sure you have already tried the power switch, try starting from Step #5 to do a hard reset on your Kindle.
