1995 Ford Thunderbird Logo
Posted on Oct 17, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The engine has blown. I need to replace it or change pistons and rings. How difficult is it to change pistons and rings?
Duane Wong
Level 3:
  • Ford Master 6,826 Answers
  • Posted on Oct 17, 2010
Duane Wong
Ford Master
Level 3:
Answers
6826
Questions
6
Helped
2861512
Points
20234
It can be time consuming and the end result may not be desirable if you haven't done it before.
--- The following is just a sample of what to do once the engine is torn down: Pistons and Connecting Rods
  1. Before installing the piston/connecting rod assembly, oil the pistons, piston rings and the cylinder walls with light engine oil. Install connecting rod bolt protectors or rubber hose onto the connecting rod bolts/studs. Also perform the following:
    1. Select the proper ring set for the size cylinder bore.
    2. Position the ring in the bore in which it is going to be used.
    3. Push the ring down into the bore area where normal ring wear is not encountered.
    4. Use the head of the piston to position the ring in the bore so that the ring is square with the cylinder wall. Use caution to avoid damage to the ring or cylinder bore.
    5. Measure the gap between the ends of the ring with a feeler gauge. Ring gap in a worn cylinder is normally greater than specification. If the ring gap is greater than the specified limits, try an oversize ring set. Fig. 5: Checking the piston ring-to-ring groove side clearance using the ring and a feeler gauge The engine has blown. I need to replace it or - tccs3923.gif
    6. Check the ring side clearance of the compression rings with a feeler gauge inserted between the ring and its lower land according to specification. The gauge should slide freely around the entire ring circumference without binding. Any wear that occurs will form a step at the inner portion of the lower land. If the lower lands have high steps, the piston should be replaced. Fig. 6: The notch on the side of the bearing cap matches the tang on the bearing insert
  2. Unless new pistons are installed, be sure to install the pistons in the cylinders from which they were removed. The numbers on the connecting rod and bearing cap must be on the same side when installed in the cylinder bore. If a connecting rod is ever transposed from one engine or cylinder to another, new bearings should be fitted and the connecting rod should be numbered to correspond with the new cylinder number. The notch on the piston head goes toward the front of the engine.
  3. Install all of the rod bearing inserts into the rods and caps. Fig. 7: Most rings are marked to show which side of the ring should face up when installed to the piston tccs3222.gif
  4. Install the rings to the pistons. Install the oil control ring first, then the second compression ring and finally the top compression ring. Use a piston ring expander tool to aid in installation and to help reduce the chance of breakage. Fig. 8: Install the piston and rod assembly into the block using a ring compressor and the The engine has blown. I need to replace it or - tccs3914.gifhammer tccs3914.gif
  5. Make sure the ring gaps are properly spaced around the circumference of the piston. Fit a piston ring compressor around the piston and slide the piston and connecting rod assembly down into the cylinder bore, pushing it in with the wooden hammer handle. Push the piston down until it is only slightly below the top of the cylinder bore. Guide the connecting rod onto the crankshaft bearing journal carefully, to avoid damaging the crankshaft.
  6. Check the bearing clearance of all the rod bearings, fitting them to the crankshaft bearing journals. Follow the procedure in the crankshaft installation above.
  7. After the bearings have been fitted, apply a light coating of assembly oil to the journals and bearings.
  8. Turn the crankshaft until the appropriate bearing journal is at the bottom of its stroke, then push the piston assembly all the way down until the connecting rod bearing seats on the crankshaft journal. Be careful not to allow the bearing cap screws to strike the crankshaft bearing journals and damage them.
  9. After the piston and connecting rod assemblies have been installed, check the connecting rod side clearance on each crankshaft journal.
  10. Prime and install the oil pump and the oil pump intake tube.
  11. Install the auxiliary/balance shaft(s)/assembly(ies).
OHV Engines CAMSHAFT, LIFTERS AND TIMING ASSEMBLY
  1. Install the camshaft.
  2. Install the lifters/followers into their bores.
  3. Install the timing gears/chain assembly.
CYLINDER HEAD(S)
  1. Install the cylinder head(s) using new gaskets.
  2. Assemble the rest of the valve train (pushrods and rocker arms and/or shafts).
OHC Engines CYLINDER HEAD(S)
  2. Install the timing sprockets/gears and the belt/chain assemblies.
Engine Covers and Components Install the timing cover(s) and oil pan. Refer to your notes and drawings made prior to disassembly and install all of the components that were removed. Install the engine into the vehicle. Engine Start-up and Break-in STARTING THE ENGINE Now that the engine is installed and every wire and hose is properly connected, go back and double check that all coolant and vacuum hoses are connected. Check that your oil drain plug is installed and properly tightened. If not already done, install a new oil filter onto the engine. Fill the crankcase with the proper amount and grade of engine oil. Fill the cooling system with a 50/50 mixture of coolant/water.
  1. Connect the vehicle battery.
  2. Start the engine. Keep your eye on your oil pressure indicator; if it does not indicate oil pressure within 10 seconds of starting, turn the vehicle OFF. WARNING
    Damage to the engine can result if it is allowed to run with no oil pressure. Check the engine oil level to make sure that it is full. Check for any leaks and if found, repair the leaks before continuing. If there is still no indication of oil pressure, you may need to prime the system.
  3. Confirm that there are no fluid leaks (oil or other).
  4. Allow the engine to reach normal operating temperature (the upper radiator hose will be hot to the touch).
  5. At this point any necessary checks or adjustments can be performed, such as ignition timing.
2answers
Nissan td 27 have a heavy blow by after overhauling the engine, what could be the problem. Sent all necessary parts to an engineer for servicing.
You describe the situation as a heavy blowby. In the usually accepted meaning of the term blowby relating to an engine, means piston blowby and is recognised by a large amount of whitish vapour being expelled through the crankcase breather, dipstick tube and the oil filler cap if removed. This usually indicates the excessive wear of cylinder bores, pistons and piston rings that are no longer capable of sealing and allow combustion gas to blowby.
If the vapour puffs in sympathy with the engine speed it suggests stuck or broken piston rings confined to a single cylinder or a damaged piston.
It is difficult to understand how this would happen with a newly overhauled engine that surely must have been rebored and had new pistons fitted in order to qualify as overhauled. I can possibly advise you further if you post details of the overhaul in the comments section.
Not unrelated but perhaps surplus information just now - new cast iron piston rings take 500 miles to bed in to new properly honed bores while steel rings take 1000 miles. It is important to complete those miles with the engine filled with a base or low grade engine oil or proper running-in oil. Filling a newly overhauled engine with a modern high-spec oil can mean the piston rings will never bed in and forever afterwards the engine ios likely to smoke and consume a lot of oil.
Hi.whats audi a3 2013 cxs engine piston ring sizes?
This is a difficult question to answer because if you are going to rebuild that, the cylinders need to be honed and that changes the sizes, you would have to micrometer the cylinders and get oversize rings. While you can order OEM sizes, they are not listed in any detail and they are not cheap.
1helpful
Toyota 2.4D 1987 model engine 2L mifires nd takes out a cloud of exhaust gases as it idles..what can be a problem
Samuel, If a diesel. injectors could be leaking and need replaced, also have a compression leak down test done and a coolant pressure test to help diagnose and see if problem with the valves or piston/rings, blown intake,cylinder head gasket.This will help diagnose engine condition,. "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Replacing piston rings
Remove engine. Dissassemble. Remove pistons. Install new rings. Reinstall pistons. Reassemble engine. Install engine.
2helpful
3answers
2003pontiac grand prix how compress the piston by compressing or by turn in ?
What you need to do is lift the car take out the wheel where crank shaft is,
also know as the harmonic balancer
Bad pistions on 94 buick centry 3.1l think engion stamp is g dont know if i have to put just pision in or rod assambly
It's rare that a piston goes bad. So, you need to determine why it failed.
Most times, the cylinder wall is damaged during a piston failure making it impossible to just replace the piston. Check the wall for score marks and out of round condition as well as actual size VS original bore size. (correcting that requires machine work) The new piston must match the cylinder bore as it is now, NOT what it was when manufactured. (same applies to rings).
The old rod can be re-used if it is not bent and providing that the big end (crank end) is still round. Again, the rod needs to be assembled by a machine shop as the wrist-pin is a press-in part.
Most times, you will find that the amount of actual work necessary to replace one piston exceeds what would be necessary to replace the engine in both time, $ and reliability.
If you want to try a replacement though, see if you can get a piston/rod assembly that is still in good condition from a blown junkyard engine, Plasti-gage the bearing and replace if necessary, clean out the ring grooves or replace the rings. Use a hand held cylinder hone and break the glaze on the cylinder walls. If you are careful and everything goes well, it MIGHT work.
Personally I would never replace pistons in an engine without doing all the necessary machine work though.
3answers
Air blowing out of oil cap on ford escort
Check PCV valve by pulling out of valve cover with hose attached. Start engine and verify the valve is sucking air. If yes, your piston rings are worn out and allowing combustion gasses into the crankcase. This is too much for the PCV system to handle. Recommend checking compression on all cylinders--may be just one piston. Let us know if you have more questions.
My hyundai accent piston rings need a change how
If it needs rings, it probably needs a lot of other engine work, like a cylinder hone, or if it's out of spec, a bore, which means new pistons and on. You might look into a good remanufactured engine that comes with a warrantee if your has a ton of miles on it.
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
