Microsoft Zune JS8-00001 Digital Media Player Logo
Posted on Oct 17, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have not used my zune for a few months now but need to use an mp3 player so i am trying to use it again. When i plug it in to my computer using the usb cord the little battery charging sign comes up then fades away. Its been on the charger for a while and keeps doing the same thing but wont turn on. What do you think the problem is?
Anonymous
Level 2:
New Friend:
  • Expert 58 Answers
  • Posted on Jan 14, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
58
Questions
0
Helped
7698
Points
167
First, you must not use the front usb ports on your cpu. You must plug your zune device in the back usb port. You must then download the LATEST Zune software. Install it and restart your computer. If done correctly, your Zune device will begin to charge and start working correctly. Have fun with your device
120gb Zune won't turn on or charge
No probley not it needs a new battery more than likely they can be bought for around $25.00 or so no fun to put in very delicate.
1helpful
Zune is completely dead when not plugged into my computer
the battery is not retaining any power. the only reason it works while it is plugged in is because there is power go directly to the battery
2answers
My zune is not recognized by my pc
Try rebooting the computer, starting the Zune software and plugging it in again. If this doesn't fix the problem, try uninstalling/reinstalling Zune software, then reboot the computer and plug it in again. If it still doesn't work, then the computer will have to be restored to an earlier date where the pc recognized the zune.
Trying to plug in zune but computer won't recognize it.
You might need to reinstall the drivers, or update your USB port drivers.
A nice zune troubleshooting guide on this is available on fixing zune device errors.
Hope it helps.
Jules
2helpful
2answers
My Zune wont turn on
Press up and the back button at the same time for about ten seconds. This should reset your zune.
I have Zune 30GB mp3 player. When I try to charge it using computer or wall charger, it tries to turn on and makes some clicking sound and turns off again. It does it repeatedly but can not charge it.
the zune does this if the battery doesn't work (needs a charged battery to power on). battery is either defective or disconnected. there is a zune repair guide that shows you how to fix it
Zune reset
Hi I can help you this is how. BUY A 4G ZUNE!!!!! cause your 30g zune is broken or something, or reset everything and instal it again
2answers
Problem with intalling zune's software
Uninstall all zune software and download and install it again. Possibly a bad download.
Or run error check on your computer then try it again.
Go to my computer, right-click on C: - go to properties- then go to TOOLS tab. Click on Error check - make sure you have both boxe(s) checked to fix errors as they are found then hit start. You will have to restart your computer for this check to happen. Usually takes a a few hours, but recommended to do at least once every few months.
Hope this helps!
My zune wont work on my computer
Have you tried using another cable? the cable may be fried...
or a different computer to see if it just doesn't like your computer.
Zune
Try resetting the Zune by holding the up and back keys until it restarts (probably about 10 seconds) and then try to plug it into the computer again.
Top Microsoft Audio Players & Recorders Experts
john h
Vinho Xie
Vinho Xie
Rick Rock
Rick Rock
Are you a Microsoft Audio Player and Recorder Expert? Answer questions, earn points and help others
