You need to put the bluetooth device in discover mode, then on the cell phone, you configure the blue tooth settings to "find" the bluetooth headset. Check out this document on how to pair a Jabra (may not be your model, but bet it is the same process). Good Luck!!
http://www.jabra.com/sites/Jabra/GNimages/Products/WirelessHeadset/BT350/Documents/BT350_UM_NA_EN_491.pdf
SOURCE: Reseting Jabra Bluetooth
Jabra headsets sometimes have a different way of being put into discovery mode. Most headsets just have you press and hold the big call button on it. Some jabra headsets require you to JUST hold down both volume buttons and some other jabra headsets require you to hold down ALL buttons on the headset to put it in discovery mode (or pairing mode as they sometimes call it)
Try of those combinations ... The light will stay solid when it's in discovery mode... Once the light is solid THEN have the EnV search for headsets.
hope this helps
SOURCE: i hav a jabra bluetooth....type
1. Put the headset in pairing mode and make sure that the
headset is on. To do this: Press the answer/end button and press the volume up
(+) button at the same time, until a solid blue light comes on.
2. Set your Bluetooth phone to ‘discover’ the Jabra headset
(Follow your phone’s instruction guide to do this)
3. Once your phone locates the headset, it will ask you for
a code to pair with it, the code for jabra headsets is usually 0000
