Yes Bunn will send you a repair kit free of charge. Just apply a bead of silicon below the rubber gasket before you tighten it down and it will solve the problem.
The only place I know of that you might be able to find a replacement tray for this style of brewer is from your local Bunn repair shop IF they have a used unit laying around that died from something else. Bunn will not even send out these parts to their repair centers. Good luck!!
Try taking the top off the unit (3 screws) and remove the pour-in tray (1 bolt) and turn the thermostat down. Replace the tray - making sure you put the silicone washer in - put the lid on, and try it again. If this doesn't cure it, your thermostat is bad, and you need to replace the unit.
clean your spray head by removing it and at the same time run the cleaning spring up through where the spray head screws to. before replacing spray head place your pot under and pour a pot of water through,to rinse.when done replace spray head .wait for it to heat up and your set to brew again...
