There is no fix, it is a Pixel gone out in display panel, good chance it is just stuck and will right itself but sadly sometimes they dont and the only fix is to replace the entire display panel Manufactures warrant such defects different depending on amount of dead pixels on screen is considered faulty, ie 3 pixels grouped or 5 separate ones .
could be a dead pixel you can some times get them back by tapping the pixel with the stylus off a nintendo ds have the tv on a white screen when doing it so you can see when it has worked. need to tap just the pixel square do it to each pixel.
A dirt spot, use hot water on a soft cloth to clean it.
Dead pixels, you can try this, keep moving between screen and sometimes this will unstick bad pixels.
Go here, then click F11, now RT click mouse button as fast as your finger can. do it like 20 times.
Now click F11 on the page that shows the words dead pixel test. If they are still there you will need to check your warranty and see how many the company allows before they will fix.
sorry to tell you this I had this problem on a 60inch Mitusbishi No fix is possible is the pixels are burning out and replacing the bulb as I did was a costly no help repair. I finally watched it till it got so bad and i donated it to good will wish I had better news.
Not possible.Tv have damages to it LCD screen panel by an object or a person have causes by forced or putting pressure to the tv LCD screen panel itself to causing colors picture pixels and it radiation to died to causing this problems.Sorry it time to buy a new tv,because by replacing the tv LCD screen panel itself will cost u the same as a new tv.Tries buy a new tv from the VIZIO tv corporation directly return the damages LCD panel tv to them,u could get a 5 or 10% off of the tv prices.
its a light engine starting to fail it will require replacement you may want to contact hitachi customer relations and ask if they offer assistance with this have model serial and recipet for date of purchase
