SOURCE: Turbine/moaning sound and vibration
The grinding sound that you are hearing is your color wheel. They can make a noise from a buzz to a power saw type of noise. Usually the set will continue to play with the noise, but it is annoying. You will need to replace the color wheel now.
This is not as easy as the lamp replacement, as you have to pull the light engine to access the color wheel. It is not hard just more work and be careful of the color wheel lenses.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up) If you cant rate this post with the highest rating, then please comment to this post and I will try to help you further.
SOURCE: Samsung HLR5078W pop sound followed by a loud buzz then shut down
Your lamp burst. This model uses a lamp housing which does not have a filter screen on it. When the lamp bursts, hot pieces of glass and mercury (very toxic) drop straight down into the cooling fan below it. Although FixYa.com (implies I'm suppose to tell you how to fix it) I am going to tell you to call a servicer and have them clean that mess out of there. It's a health issue, I don't want someone unknowingly exposed to mercury on my watch. Let the servicer know what he is getting into. I hope this helps.
SOURCE: I REPLACED THE LAMP ON
I would suggest a simple way to know if color wheel or not; usually color wheel makes high pitched whine or even a grinding sound (like a bad fan).
If you remove the lamp and look carefully where it faces the color wheel is there; you are looking to see if it is shattered or missing pieces etc.
What happens is if the wheel shattered or even slowed way down the set will detect this and shut down. The bearings in the tiny motor for the wheel lock up etc as it is turning at over 12,000 rpm.
If you find it is shattered they are available on the net with video instructions for most models; there are a few things to be aware of that are not usually mentioned when you buy a new wheel and I if you go that route I can tell you a few common pitfalls to avoid.
If you have questions or need assistance let me know, I am here to help.
SD TECH
