HP Support > Pavilion a430n desktop computer > Software and Driver Downloads, (XP O/S)
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=228&lc=en&cc=us&dlc=en&sw_lang=&product=389932
Click on the + sign to the left of - Original Drivers (10)
Then scroll down to - Spring 2004 Original Network Adapter Driver Collection, and click on More info.
Under the heading - Details and specifications heading, and to the right of File name: click on - sp24008.exe
In the small window that comes up click on Save File.
Look at the heading of small download window. See where the file is being downloaded to.
(My Documents? Sub-folder within My Documents - Downloads?
Or Desktop {desktop screen)
Double-click on the file name, follow the Installation Wizard instructions.
(Essentially just click on Next, Next, and Finish)
If you find this does not work after installing, you may want to look into buying an Ethernet Adapter Card, and installing into a unused PCI Slot.
1) Product Specifications for the Pavilion a430n:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00055520&cc=us&lc=en&dlc=en&product=389932&tmp_track_link=ot_search
2) Motherboard Specifications:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00063027&tmp_track_link=ot_recdoc/c00055520/en_us/c00063027/loc:1&lc=en&dlc=en&cc=us&product=389932
(Motherboard illustration and photo at bottom of the page)
Example of a PCI Ethernet Adapter Card,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=686143&CatId=200
If you are looking for the driver, please click on this link:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&product=389932&os=228
You have to select the correct operating system used and then it should show you a list of drivers available. And then you can start downloading.
SOURCE: hp pavilion a430n power supply is blinking
Look at this photo
(http://www.atxpowersupplies.com/images/300-watt-atx-power-supply-FSP-ATX-300GU-350w.gif)
Did you connect the p4 atx 12vx1 plug?
You may also need to connect the aux x1 plug on some models.
SOURCE: Want to download drivers for
Hi, According to your requirement, visit http://h20000.www2.hp.com/bizsupport/TechSupport/ProductList.jsp?lang=en&cc=us&taskId=135&prodTypeId=12454&prodSeriesId=384501.
Then select your desktop model
and the windows version. There you will found all drivers, select your required
driver and download it. So it is too easy to download.
