SOURCE: connect jabra to blackberry
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.
3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select BT150 once a connection is detected.
5.The passkey "0000" is now entered to confirm the connection has been made.
6.The cell phone screen will now read "Bluetooth Connection".
Tips:
1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works.
Thanks for using FixYa.
SOURCE: Pairing Jabra BT4051 to my blackberry
I paired my BT4051 with my BB curve just fine. I held down the power button on the Jabra until the blue light was solid and then added the device through my BB's bluetooth setup under options.
SOURCE: Igave been using my Verizon Jabra VBT185Z
where can I find the setting on my Blackberry Curve to pair my Jabra VBT185z
SOURCE: can not find instructions to connect jabra bt8040
Go to this site, and it will walk you through each step to connect your
particular Jabra headset with your cellphone. Choose the headset, and
then at the next page, choose your phone. Moving your mouse over each
step will change the picture to what you should be seeing on your phone
at each step.
http://jabra.pairx.co.uk/ Pls come back and let us know if this solved your problem.
SOURCE: I have been given a Jabra BT 250v hands free head set
It should have come with a small 45 mm diameter cradle base unit which the mains has a 1.4 mm jack plug plugs in and the headset rests in.
Look for it on Jabra support website or pictures on a search on Ebay
Search on Ebay for one for a replacement.
