Question about Car Audio & Video
Owner's manual needed for a Pioneer EEQ MOSFET 50WX4 Super Tuner III D
Do you have one available? What more can I say, I have the receiver right in front of me.
  • Anonymous Dec 07, 2008
    looking for the manual
  • jojoe me
    jojoe me Oct 29, 2013
    it is deh-16
    New Friend:
Http://audio.manualsonline.com/manuals/mfg/pioneer/fmam_deh1800.html
The link above will get you to the pdf. user manual.
The EEQ MOSFET 50wx4 is also known as DEH-1800.
Posted on Oct 30, 2009
    New Friend:
I have the aux hooked up to my phone and the aux turned on but it still won't play
Posted on Jun 23, 2012
A dvd just got stuck in my radio any idea on how to take it out
Posted on Jul 26, 2009
    New Friend:
Want to put a picture on my screen
Posted on Apr 24, 2011
    New Friend:
I keep getting an error coming up wen I try to connect my mobile threw blue tooth any ideas
Posted on Mar 12, 2017
Turn the tuner off, With the clock display on Push and hold down the white button on the top right side, (right top corner) the Hour LED will start to flash, use the four arrow adjustment button on the right side to adjust
Posted on Oct 16, 2008
SOURCE:
How to replace olevia lt37hvs ir receiver replacement
You may find this is impossible to do---the receiver if the set has buttons on front will be located there--if on same tiny circuit board as buttons you will have to TRY to find a replacement board--Good luck as this brand often NO parts are available.
While all IR receivers are similar they have different values and mountings.
I will presume you had the remote itself TESTED which will rule it in or out.
Ir receivers sometimes show no function unless remote is right up very close are bad---they also of course can fail where there is not any responses shown.
Apr 29, 2012 | Olevia LT37HVS 37 in. LCD HDTV
Tanaka htr 5660 was working fine. Not sure what button I hit, but sub and rear surround quit working. I have followed troubleshooting guides and to no avail. Connections are all fine as well
You must have hit the DIRECT button . In this mode it produces pure stereo sound by shutting down the multichannel Digital Sound Processor (DSP). Only your front Left & Right speakers will work
Mar 10, 2011 | Yamaha HTR-5660 Receiver
WIRE CODES FOR XA311
white - front left positive
white with black stripe - front left negative
grey - front right positive
grey with black stripe - front right negative
green - left rear positive
green with black stripe - left rear negative
violet - right rear positive
violet with black stripe - right rear negative
Red- accessory (power that is only present when the ignition switch is in the on or acc position).
Yellow-constant power (keeps radio stations programmed, time set, etc.)
Black -ground
Other wires are used for hooking up an amp, power antenna disc changer, etc..
Clarion's FAQ is also available if you need more information.
http://www.clarion.com/us/en/support/faq/Audio/index.html
Mar 01, 2011 | Clarion Car Audio & Video
Can i connect bose 901 to denon avr891? with 901 eq that required "tape monitor '
Two problems:
1) You have no specific Front Right and Left Pre-Outs. Using the available DVR Out, for example, would feed mixed-down stereo full voume programming instead of volume-controllable Front Channel-only output.
2) If you had them you would still need a separate amp for the 901's as its Active EQ is unsuitable for 'normal' non-901 speakers and engagement of any analog processor in an analog tape loop (like DVR Out/In) would effectively kill any digital source. It WOULD only work for analog sources.
Jan 05, 2011 | Denon AVR991 Receiver
I have a EEQ MOSFET 50wx4 car stereo. NO MANUAL......can't figure out how to set the clock. CAN YOU HELP???? Pioneer website is not too user friendly!!
I have same problem. Try this link for the manual (similar model) http://www.pioneerelectronics.com/PUSA/Products/CarAudioVideo/In-Dash/CD-Players/DEH-P6500?tab=D
click on owners manual, half way down. Once its downloaded page 32 talks through clock settings. You have to switch the headunit off at the source button - Good Luck.
Sep 28, 2010 | Pioneer GPS AVIC-X1 car radio
Sony STR-DE875 receiver has no sound from right channel front or back. Checked for loose connections & blew out dust, no change
Hy all. I bought a receiver at last week. But the front speakers not working. The rele is jumping just.
i repaired them ! the rele colour is blue. Three percent . left first -Center, between -Surround, between(right Hand)-Front.
I moved the front channel's rele(right hand) .Katt -it sad. Working, volume is back. Rele specification is (colour Blue) Deg Greatings-Ranger of Hungary.10_26_2012_6_50_16_am.jpg
Aug 23, 2010 | Sony STR-DE875 Receiver
How to connect sony video camera to yamaha htr 6230? I put the yellow in the video white in left and red in right audio in the v-aux in the front of the receiver. For some reason it is not displaying the...
How are you connecting the TV to the receiver? The receiver offers HDMI, component video and composite video outputs. The one you use will depend on what inputs are available on your TV. Whichever you choose, have the appropriate cables connected at both ends. Then make sure the proper source is selected on the TV and your camera output should be visible. The receiver manual is available for download at Yamaha's site if you need a copy for connection details.
Mar 23, 2010 | Yamaha HTR-6130 Receiver
Receives faxes ok, but when a voice call comes in a fax tone sounds on on the calling and receiving phone after 3 rings.
Depending on the model, you can set to fax only (which you have), fax/phone mode (starts up for a fax and re-rings for a voice call), or manual receive (YOU must press start to receive a fax. Some models have the options right on the front control panel. Some require programming to be accessed. Either way, an owners manual may be available online.
Please rate me if this helps.
Jan 15, 2010 | Office Equipment & Supplies
How do i connect an ipod to a pioneer mosfet 50wx4 car stereo, do I need a certain part?
unless you have a headphone jack or rca input in the back
i really dont know the deck but thats the 2 easy ways
Jan 08, 2010 | Pioneer XM CD REMOTE MOSFET50 EEQ
Car Audio & Video Logo
50,701 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
