Hi i just bought my acer one 10.1 ins laptop and it was working fine wirelessly about a week now and it cant connect. The wireless switch wont turn on but i cant connect with the ethernet cable. How can i connect wirelessly?
Jun 17, 2014 - In some Acer models you can use a combination of keys on the keyboard to ..... My acer aspire wont connect with wifi, it say windows cant connect.... I've just had a similar problem with my Acer Aspire laptop (wireless .... It is startedto happen just a month ago before it was ok I am using this since 6 months.
Wireless problems can have various causes. Do other devices in your network work fine (other notebooks, smartphones)? And have you tested your Acer in other networks, like in a friends house, etc? If your notebook fails anywhere you use it, it may have a faulty wireless adapter (altough that's very rare). I would try to remove and reinstall the wireless driver and if that don't solve it, reinstall the OS (you could also have a virus problem). If the notebook works fine in other places, it could be your wifi router. Try turning it off and on.
Some laptops have switches that you have to turn on manually in order ffor it to work look for a switch usually on bottom of the laptop under or near touchpad
On the side edge or on the front edge of the laptop there should be a wireless switch or a clear button, when you activate it the wireless light should light up amber/orange.
Does the Acer have a built in wireless LAN card?
If so are the drivers installed?
Go to the Control Panel, then Network Connections to verify the wireless connection etc..
If you don't has a wireless card you will need to get a PCMCIA wireless card and install the drivers and configure it to suit your wireless router configuration.
The connection between the laptop's internal wireless antenna and its wireless card may been disconnected. Best to take it in to a computer shop for fixing. If you want to fix it, open the PCI-E cover on the bottom of the laptop, then reconnect the antenna wire. If that doesn't work, get it serviced.
