SOURCE: Barcode scanner scans and beeps, but will not put the numbers in the computer
There is more than one way for that imager to send data to the computer. Are you using USB, serial, or is there a little box that goes between your existing keyboard and the PC that accepts the scanner connector?
SOURCE: Symbol LS 4278 Barcode Scanner - 3 Clicks
Does it beep each time you pull the trigger while the beem is on the barcode?
SOURCE: Need manual to reset barcodes on PSC VS800
ok, download from the blow link ---
http://www.download-manual.com/shop/PSC-VS800-Compact-Manual-pr-1187.html
cost--- 8.95 USD
SOURCE: BARCODE SOLUTION
Dear Mayur,
Can you pls write what you want to do with barcode printer and scanner
Mail Me.at [email protected] or [email protected]
Deepak
SOURCE: will not transmit to Shop and Scan website when
Did you ever get it to transmit the barcodes?
I'm having very much the same problem. Got the error 3 message first, then was told to delete the add on in manage add ons. Now i get an error 2.
