Pls provide driver asap re: above subject
tks
SOURCE: installation driver for microtek scanmaker 4900
Here is the link to order the driver, however you will need to enter your op system to get the correct one, since you have not entered it here. Please Note:
Turn off and disconnect your scanner.
Before you down load the driver, turn off all running programs including your security/firewall. Go to the the little icons on the lower right and click on them and exit or turn off all that you can. Download the driver to your desktop. It will be an exe file. Then click on it to install and follow directions.If you have not been instructed to connect your scanner during the setup, do so now.
When you are finished restart your computer.
Thank you for using Fix YA! If your problem is solved, don't forget to rate us. Thanks!
No Vista 64bit driver for Microtek Scanmaker 4900
Please provide me a copy of driver for Microtek Scanmaker 4900 flatbed scanner.
thank you.
