Whirlpool Duet GHW9150P Front Load Washer Logo
Posted on Oct 16, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I am getting error code d5 on my duet sport. How do I fix this?
Anonymous
Level 3:
  • Master 618 Answers
  • Posted on Oct 16, 2010
Anonymous
Master
Level 3:
Answers
618
Questions
Helped
128733
Points
1840
No d5 there is F05 Du> and DL The F05 is water not being heated . The D is for door switch not locking or unlocking .Must have complete model from washer to be sure
What is code message F02?
Repairing the F02 error code can usually be done without ordering parts. Tools needed to repair your whirlpool Duet F02 error code are towels and a quarter inch socket.
Tip the washer back at a 45 degree angle. On the bottom panel there are three or four screws, with the screws removed the panel will slide down and off. With the lower access panel now removed you will have access to the washers drain pump clean out.
With the water already bailed from the washer you can twist the filter head counter-clockwise to remove. Twisting the filter head counter-clockwise will loosen filter so it can be pulled out.
With the filter out clean and install it back into washer.
Run a quick cycle to ensure the washer is back up and running and the F02 error has disappeared. If the error comes back, it may require you to clean the drain pump filter again.
If you require a new drain pump motor, you can purchase the part from the link below.
- See more at: http://www.appliancerepairlesson.com/2011/03/12/how-to-fix-whirlpool-duet-error-code-f02-duet-sport-error-f02-fix/#sthash.PuGd0iuQ.dpuf
1helpful
How do I clear error code F-28 on my Whirlpool Duet Sport electric dryer?
The tech sheet is located under the kick /service panel in a jacket. Suggetions and codes are in it. Duet sport service manual
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
1helpful
Washer stops during cycle with an error F20
Hi
Please check this link to get error F 20 resolved:-
http://www.appliancerepairlesson.com/2011/03/12/how-to-fix-whirlpool-duet-sport-error-code-f20-washer-repair-troubleshooting/
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Whirlpool Duet Sport Model WFW8300SW0 basket won't
The following list of codes indicates an electronics communication problem with the washer: - Duet HT washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
I would first replace the door latch/lock assembly, a number of users have and it fixed the F-11 error code completely. Its the cheapest part for this problem.
Hope helps.
I have D5 error?
D5 error is due to defective door lock switch.
You will need to have this damaged mechanism replaced to fix this problem.
1helpful
What does code d5 mean? The machine will stop and stay idle for several minutes and then start again. This happens several times per load, but eventually finishes.
Hi, The reason for d5 error is due to defective door lock switch. You will need to have this damaged mechanism replaced to fix this problem.
2helpful
2answers
Whirlpool dryer duet sport MOD WED8300SW error message
I have a whirlpool duet sport electric dryer with an error code of F 26.
Mar 02, 2010 • Dryers
1helpful
Whirlpool duet sport machine will stop mid-cycle and all lights will flash and d5 will show on display
The display is actually reading "Sd", which is a Suds detect error. This is an indication that you have either used too much detergent, are using the wrong type of detergent, or you have an obstruction somewhere in the drainage system. The following link explains the error code and how to correct it:
http://www.fixya.com/support/r3608687-sud_error
There is a follow-on link included that explains the steps necessary to check the drain pump reservoir. Read through the information provided and let me know if you have any questions. I hope this helps you.
Whirlpool duet f21 and d5 codes
You have me there, my book I learned from doesn't show any d codes.
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
