Question about Dell Laptop InspironTM 1501 PC Notebook
I have a dell xps m1530 the hdd stoped working i didnt get any error message i purchased new hdd and installed still blue screen no error message i removed new hdd and turned the laptop on all i get is blue screen and two beeps
  • f_morales41 Oct 16, 2010
    shouldnt a blank hdd say something on your screen when installed
  • Dell Master
  • 5,660 Answers
F_morales41, before you installed the new Harddrive, did you,
1) Install the Operating System disk?
2) Install a fresh (New) genuine copy of Windows?
The Harddrive has your Operating System on it. (Windows XP, Windows Vista, and Windows 7 are examples of an O/S)
You can't just put a new Harddrive in. It is blank.
This is why you can't remove the Harddrive, and expect the laptop to work, also.
Put the new HDD in, power up the laptop, install the Operating System CD disk in the optical drive, (CD/DVD drive)
After the Operating System has been installed, (Software completely loaded), put the Drivers and Utility's disk in. Load it.
Posted on Oct 16, 2010
  • joecoolvette
    joecoolvette Oct 16, 2010
    Do you have the new Harddrive in? Put the Operating Disk (CD) in the optical drive. Load the software. Then put the Drivers and Utilities Disk in. Tell me what happens.
    Thanks for the rating! Most appreciated!
  • joecoolvette
    joecoolvette Oct 18, 2010
    Thank you for the rating f_morales41, Most Appreciated!
  • 244 Answers
Two beeps usually means the memory module went bad.
Replace it and you should be ok
Good Luck.
Dont forget to rate this answer if it helps
Testimonial: "sounds like a good idea thanks.ill try it the laptop is only 2 years and i paid alot"
SOURCE:
Battery installed power shows but not charging battery, new battery and charger. thanks.
Hi
Its a common issue for DELL Laptops usually if the battery and charger are working fine the culprit is the motherboard. If its still under warranty have them replace the motherboard and it will be good as new.Thanks
Feb 08, 2011 | Dell Inspiron XPS Series Notebook: XPS...
My Dell XPS M1530 has a flashing "X" on my battery. It says 'Consider replacing your battery'. It still charges but I don't know what to do.
This message is a indicator that your battery is approaching
EOL ( end of life) however it will continue to work normally what you can do is consideer buying a new battery at your convience
Dont forget to say thanks
Aug 11, 2010 | Dell XPS M1530 Notebook
I Have an XPS M1530 which won't switch on.
replace the motherboard. You can find the part cheaper than dell here at
www.partpeople.com they specialize in dell replacement parts.
Just type in XPS M1530 in the search box to see if they have the product,
Also if they dont
then contact Dell Spare Parts Division
1-800-456-3355
Apr 14, 2010 | Computers & Internet
Problem with display in DELL XPS M1530
Your video driver crashed. Have you installed a video game or Fusion tv tuner recently. deinstal and reload your video driver. holding down the F8 key while booting go into control mode (which doesn't load drivers) delete app, then load drivers from your CD.
Sep 10, 2009 | Dell XPS M1530 Laptop
My dell xps m1530 laptop the eject botton does not work"
are you talking after it boots to windows
if so click for the hardware to be added
If not please explain
Jan 28, 2009 | Dell XPS M1530 Notebook
I have dell xps m1530 laptop the eject botton does not work
what software do you want to install for what purpose....>????
you have have connected a new device hence its asking to install the new drivers for the hardware...!!!
Dell XPS M1530
On your laptop, press and hold the <Fn> key while powering the system on. This will initiate a diagnostic routine to check your hardware. Since this is a new purchase, call Dell about this issue and relay results of diagnostics, even if no errors are detected and diags pass.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 04, 2008 | Dell XPS M1530 Laptop
Dell Laptop InspironTM 1501 PC Notebook Logo
128 people viewed this question
Clive
Clive
Alun Cox
