Sorry even though you have provided a lot of detail about the components you have connected to the Onkyo receiver, I am very unclear about the configuration that is not working properly.
1. I will assume that when you connect HDMI output from COMCAST to Onkyo and then video pass-through HDMI from Onkyo to Sony TV then you are getting proper video on TV and sound from Onkyo. Is that correct?
2. I will assume when you connect the PS3 HDMI output to Onkyo with video pass-through HDMI from Onkyo to TV, then you are also getting proper sound and video.
3. I will assume when you connect the Apple TV HDMI output to TV HDMI input then you are getting proper sound and video from TV.
4. I will assume that when you connect HDMI output from COMCAST to Onkyo HDMI input and also the Apple TV HDMI output to Onkyo and then video pass-through HDMI from Onkyo to Sony TV you are getting no sound from Onkyo and only flashes of video on Apple TV. I am assuming you are using HDMI input 1 and input 2 to connect the COMCAST and Apple TV? Is that correct?
Are you aware that AppleTV does not support HD TV mode?
Please confirm if situation 4 is the problem you are having. Also is your Onkyo SR605 or SR705?
You have written 605 and one place and 705 at the other.
Will be happy to help you sort this out when you provide the clarification above.
Thanks for the update.
Sorry about miscalling the TV as sony Tv.
In light of the clarification you have provided (and thanks for your patience), it is obvious that the Sony PS HDMI output is distinctly compatible to what the Onkyo wants.
So something is not OK with the settings when it comes to Comcast and Apple TV outputs.
Apple TV output is only 780 x 480 or therabouts which is not HD format. But that should not affect the sound not coming from the Onkyo. I do not have access at this stage to the Onkyo 705 settings - I will look into this in about 7 hours from now as I am currently mobile. In the meantime if you have time you can play around with the Digital audio format settings that is available in the Onkyo 705 audio settings and see if there is any breakthrough.
Regarding the Comcast - if you get Apple TV working first we can tackle it next. You do have Comcast III which is the true HD version so once again it could be the audio setting on the Onkyo.
Will contact again in 7 hours.
Hi
Thanks for your answer.
Here my answers:
That is not correct, I do not get video nor sound. Also My tv is HP MD5880n.
Correct.
I am not connecting in this way. I want all device connected through the onkyo, speciffically the APPLETv connected HDMI
I have the same problem, connecting only one device ( APPLE Tv or COMCAST) or connecting both devices, using any combinations of HDMI input 1 or 2.
Are you aware that AppleTV does not support HD TV mode? No, i am not sure what it means.
Please confirm if situation 4 is the problem you are having. Also is your Onkyo SR605 or SR705? SR705
