I was cleaning the range panel and I somehow pressed a button that locked the oven door. I have tried everything in the owner's manual to unlock the door but to no avail. The display panel says F5:E7, what does that mean?
same exact thing, cleaning, and door locked, and the same message F5:E7. Unbelievable that there is no where to find what this means...same exact thing, cleaning, and door locked, and the same message F5:E7. Unbelievable that there is no where to find what this means...
AnonymousJan 04, 2009
f5e7 appears and I cannot unlock the oven door. Help!
You can't post conmments that contain an email address.
Quoting from the link shown:
Step 1
Read the display on the electronic oven controls, where the clock and timer normally appear. If the display reads "CLN" while the "Door Locked" light is on, the Kenmore range is in self-clean mode. When the Kenmore range is in self-clean mode, you must stop the cleaning process before the door will unlock.
Step 2
Stop the self-cleaning process by pressing and holding the "Stop/Clear" button for three seconds. The oven lock should disengage after three seconds. In some cases, a malfunction between the control panel and the locking mechanism prevents the door from unlocking.
Step 3
Hold the light switch for several seconds if the "Stop/Clear" button fails to unlock the range door. Engaging the light switch for several seconds resets the entire locking mechanism and overrides the "Stop/Clear" button.
Step 1
Step 2
Step 3
The oven door lock needs approximately 1 hour to cool down before the oven door can be opened after a self cleaning cycle has finished. If the lock does not open after the oven has cooled down, you can try....1) Unplugging the range or shut off the circuit breaker for 5 minutes. Plug the range back in or turn on the circuit breaker. Set the clock and try moving the door lock lever or opening the door. 2) Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever or opening the door. Most ranges today use 3 different types of door locks...one is a solenoid controlled lock ( you hear a loud buzz noise when setting or unlocking the lock and has a arm that you must move to set the lock )...another is a heat sensitive lock ( has a arm that you must move to lock and un-lock, makes no noises and has a spring that slowly moves to lock the door will the oven is heating up )...Some locks are motorized ( no handle to move, the motor locks the door by it's self when you set the range for self clean )... If the motorized and heat sensitive locks fails to open after the self clean cycle, you must access the lock and move it yourself to open the door. On the free standing ranges, most times you must lift the cook top to access the lock mechanism. On built in ovens, the oven must be pulled out to remove the top access panel to get at the lock mechanism. Some build in ovens can have the control console removed to access the lock system. On the heat sensitive style of lock, there are no electrical parts to operate the lock, usually you will need to replace the lock. On the motorized style of lock, you will have to use a ohm/volt meter to test why the motor will not work. On the solenoid style of lock, the solenoid is often mounted on the back of the range and can be accessed by removing the rear panel, some may be mounted at the front, such as in a built in oven. The failure of the solenoid style of lock is normally caused by a bad lock solenoid. In order to get your door open, you must operate the door latch mechanism manually. Unplug or remove power from the range. Take the rear cover off the range. Locate the door latch assembly and operate it manually and open your door. Then check continuity of the solenoid. Some of the latch assemblies have micro switches to supply power also. You may need to check them. You should be able to get the door open and use your range until you can get a tech to repair if you can not repair yourself. There may be a door activated* switch on the front face of the oven. In this case you may need to manually press that door switch with your finger while at the same time canceling the clean cycle to get the latch to retract so the door can close fully again. *On -some- Frigidaire built ranges, the switch is located behind the right hand side panel and activated by the right hand door hinge. On this model, the side panel may need to be removed to access a malfunctioning door switch.
Please do rate the solution as FixYa and revert for further assistance.
Just hold in the oven light switch around the oven door area, then press the cancel button and wait a few seconds. It will reset.
www.applianceoutletservice.com to chat with me live
Bill
WHEN THE DOOR IS LOCKED ON A SELF-CLEANING RANGE, AND THE TEMP GETS ABOVE 400 DEGREES, IT LOCKS THE LATCHING ASSEMBLY SO YOU CAN'T OPEN THE DOOR AND GET SCORCHED. IF YOU FORCED THE HANDLE TO TRY TO OPEN IT, YOU BENT THE ARM OF THE LATCHING ASSEMBLY. IN ORDER TO RELEASE THE LATCH,
ONLY IF YOU FORCED IT TO THE OPEN POSITION, YOU MUST FORCE IT BACK TO THE LOCK POSITION TO STRAIGHTEN THE ARM.THEN IT MIGHT RELEASE.
IF YOUR RANGE HAS A LOCK BUTTON THAT NEEDS TO BE
PRESSED TO SLIDE THE LATCH TO THE LOCK POSITION,
YOU WILL HAVE TO SET ALL CONTROLS BACK INTO THE CLEAN POSITION AND PRESS THE LOCK BUTTON TO RELEASE THE LOCK ON THE LATCH ASSEMBLY. YOU SHOULD HEAR A BUZZING OR HUMMING SOUND WHEN THE BUTTON IS PRESSED.
most of the time a simple fix....
http://www.geappliances.com/search/fast/infobase/10004586.htm
you have to trick the door lock mech into cycling through the cleaning process (takes about 20 seconds)
PrintRange - “LOCKED DOOR” flashes in the display
If “LOCKED DOOR” is flashing in the display of your range or oven, and the self-clean cycle has not been selected, follow the steps below to reset your control:
Motorized Switch
With the door open, locate the door jamb switch on the face of the oven. It will look like a small black post or dowel.
Push it in until the oven cavity light goes off, indicating that the oven believes the door is closed.
While you hold the door jamb switch in this position, complete the following steps.
Press the Clean pad, wait 10 seconds.
When the cycle initiates, press the clear/off or cancel pad immediately to cancel it.
Wait 10 seconds for the display to clear.
The door should unlock and there should not be a need for service.
Manual Switch
Press the Clean pad.
Close the door.
Slide the latch to lock the door.
Hit the cancel button immediately.
Unlock the door.
If the above does not correct the situation, a service technician will need to check your cooking product. To obtain in or out of warranty repair on Major Appliances, you may call 1-800-GE-CARES (800-432-2737) or schedule service online.
