SOURCE: punch 100a2 problem ouch
Double check the ground make sure you have a clean connection. check the ohm load on the speaker should be around four ohm. Or just try another speaker. And just temporary run a jumper wire from the positve to the remote unhook the remote from the radio first. It is possible you have 12 volts but if you have a bad connection it can drop off and send the amp into a default. and it looks like you have 12 volts. you have the 12 volts but no amps. Its a long shot but better than nothing. By the way if you call Rocford Fosgate they will email you a schematic for free if it is an archive file atleast they used to. Go to the website there you should find a contact number.
SOURCE: remote wire hook up
The Remote wire should connect to the remote turn on lead from you radio(most aftermarket radios use a blue and white or a blue wire for the remote turn on). This wire will send a 12v signal to the amp from the radio when the radio is turned on. You can disconnect the remote turn on lead from the amp and jump a wire from the terminal marked battery to the remote turn on terminal just to see if the amp powers up. Do not leave it this way however because your amp will not shut off and your battery will go dead.
SOURCE: power light vs. protect light mode
If the power light on top of the amp is on, the internal power supply is operating.
It is possible that the amp could damage the speaker if it has blown output transistors. Before you connect a speaker to it, you should measure the DC voltage across each pair of speaker terminals. If the DC voltage is more than a fraction of a volt, the amp needs to be repaired.
The amp requires an external fuse. Download the owner's manual from the rockford site.The correct fuse for the amp will be specified in the manual.
SOURCE: Help with CVR 12 (kickers) and a Power 1050 s amp (Rockford Fosgate)
Send me your email account and i will draw you a diagram and send it to you there. I will need to know if the ohms of each sub as well as the amp. I'll also need to know if the subs come with one or two voice coils.
Ciza
