JNC Computers SSF-M2  Digital Media Player Logo
Posted on Oct 15, 2010
How to reset JNC ssf m2 - JNC Computers SSF-M2 Digital Media Player
5 Related Answers
ThaMp3Doctor
ThaMp3Doctor
  • 8597 Answers
  • Posted on Jun 11, 2008
SOURCE: JNC SSF-F310PNK Mp3
The song format is most likely wrong:
read my "Tips and Tricks" on Song formats for Mp3 players: too long to repost here
Song Formats for Mp3 Players Explained
By Tha Mp3 Doctor
I have seen quite a few threads around Fixya in which the stated problem is that the Mp3 or Digital Audio Player will not load the songs; will appear to load the songs but will not actually play them in the Mp3 player once disconnected from computer; will skip the songs on the player, or show only “0:00” for file length; songs “disappear” all of a sudden (although this particular problem can be caused for many reasons not covered in this article); your store-bought/burned/ripped CD’s will not load into your Mp3 player; or get the error message “File Format Not Supported.” All of these problems occur because the user is trying to download a song format that the player does not recognize. Every music file is in a certain format. The most common music file formats are Mp3, WMA, AAC, WAV, RA, etc. Each Mp3 player only recognizes a certain number of these formats. Every Mp3 Player is different. You will have to check your Mp3 player’s product specifications (specs) or user’s manual to find out which formats your particular Mp3 player recognizes. When you try to download or sync the wrong file format, you will get one of the errors that I mentioned above.
Or, it could be a "formatting" issue:
There are two ways to format an Mp3 player - one on the computer itself, and one in Windows Media Player. Both methods will end up erasing all the songs on the player, but the player will be "good as new" after that. Sometimes reformatting in this manner will override the player's native formatting and cause problems - this can be reversed in most cases by updating the player's firmware. Firmware upgrades are available from most manufacturers' websites.
WARNING: The following procedures will erase all songs on the player.
Check if the file system is NTFS. If yes, format it to FAT or FAT32. - Connect player to computer, double-click my computer, right click on icon of mp3 player and select format. This only applies to Windows-based computers.
You can also format the player in Windows Media Player itself:
Connect your Mp3 player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "name of Mp3 player here 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
-Tha Mp3 Doctor
Anonymous
  • 3 Answers
  • Posted on May 01, 2009
SOURCE: My JNC SSF M9 20GB MP3 player not working
You have probably deleted all the formatting from it as well when you deleted the music. I did once, but I had a disk with it.
You need to find the software disk that came with the player.
Anonymous
  • Posted on Jul 01, 2009
SOURCE: lost usb cable
from whitch digital camera??
Anonymous
  • 116 Answers
  • Posted on Jul 23, 2009
SOURCE: have a JNC MP3 player model SSF-F7100PNK does not
You have to unscrew the back of the player (there should be one or two screws on the back) Then remove the battery. After you have done that, you should connect the player to the a computer and update the drivers.
nitrospawn
Ibe Chukwudi
  • 290 Answers
  • Posted on Feb 22, 2010
SOURCE: WHERE CAN I GET DRIVERS FOR JNC SSF-F320BL 2GB
try this site "downloads .cnet.com"
JNC SSF-70 digital audio player / voice recorder is not charging.
Dont charge with the Laptop. always use separate 5v USB charger like the one you have for the phones normally to charge the device
WHERE CAN I GET DRIVERS FOR JNC SSF-F320PNK 2GB
Here are a couple of websites that you can try...
  1. http://www.jnc.co.za/ServicesSupport.asp
  2. http://driverstogo.net/us/drivers.php?t202id=318&t202kw=mp3%20player%20drivers&Brand=MP3&Logo=mp3
There may not be a driver available for you online. The only other option I can give you is if you can find a customer service number for the maker of your product, called them and ask them for your driver. It may be that they are not making drivers for this product anymore because it may be out of date and they don't make drivers for that specific product anymore because of that.
Jnc movie mojo
i did a mistake and knc movie mojo didnt use a loudspeaker again
I recorded two hours of music from the FM radio using my JNC SSFM2 series MP4 player. The firmware version on the player is BKSD01NB22_32 2007-10-30 9.1.52 2005-01-09 When I stop recording I am able...
The recording from radio that did not want to work in iTunes was made in WAV format. To solve the problem I went to settings and changed recording format to MP3. When I recorded in MP3 format from the radio with my JNC SSFM2 series MP4 player and copied it into iTunes on my computer, iTunes played it without a problem.
Apparently WAV format is used on PC and MP3 is used on Apple Mac.
2answers
Hi, I´ve got this JNC SSF-M9 MP3 Player 20GB since years, but now I lost my AC Adaptor. The Its a Toshiba Harddisk inside 1.8" MK2004GAL 500mA, 3.3C and the accu is 3.7V with 1300mA. So does anybody know, which Adapter (voltage and current) Ineed for this? Please help...
Thanx Christian
MP4 jnc player 1G
dear am i have a solution for u download a new game from th internet on to her jnc
2answers
Lost usb cable
I am currently using one from a camera, just look for one with the same connection.
Top JNC Computers Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you a JNC Computers Audio Player and Recorder Expert? Answer questions, earn points and help others
