Irons Logo
Anonymous Posted on Oct 15, 2010
Where can I obtain spare anti scale filters fro the Breville Steam Generator IIN 195?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 18, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1070
Points
8
Http://www.argosspares.co.uk/cgi-bin/product.pl?PID=1904605&brand=breville&model=&part=
I had to ring Breville direct as was having trouble finding them and they said as it was purchased from Argos they will have them - so went to contact argos & found this website - hope this helps
I need a new water tank for breville steam generator iron
You should be able to find one on eBay. .. good luck!
How do I replace breville ironing catriged
Hello there,
From Breville website, there is NO insruction manual for the VIN 002 !!!!!
Go here for all of them
http://www.breville.co.uk/cat-search?cat=Irons&term=Manual
I don't know what you meant by 'cartridge' but Just looking at one randomly, it says.......
Anti-scale filter
Your iron is fitted with a permanent anti-scale filter. This filter is fixed and cannot be
removed for cleaning
Hope this helps
Why is there No steam from morphy Richards 42247 model steam generator?
It may be calcified or have lime scale. If the heater is "gummed up", it cannot heat properly. Try using either vinegar (takes longer) or an iron cleaner. You pour it in and it breaks up the scale. CLR works quite well too. Use pipe cleaners to clear out the holes in the sole plate.
9helpful
How do you reset the water filter light when you put in new filter on Breville Steam Generator please
Ok, had this too. Done some research and it looks like you have to unplug the iron from the mains , keep both the power and steam level buttons depressed and then plug in and switch on.
Chris.
18helpful
I have an bosch sensixx b5 iron and the calc clean sign keeps flashing what can i do .i have lost theinstuctions
Here you have how to solve this issue. It has been obtained from the device's manual.
2. calc'n clean The "calc'n clean" function helps to remove scale particles from the steam dispenser. The iron includes a system to warn when the dispenser needs periodically cleaning. When the "calc 'n clean" symbol lights up on the navigation display the dispenser needs cleaning. Fill the water tank. Plug in the iron and select the temperature setting . After the necessary warm-up period, unplug the iron and hold it over a sink. Position the steam regulator to the "calc'n clean" position and keep it in this position. Gently shake the iron. Boiling water and steam will come out, removing any scale or deposits that might be there. When the iron stops dripping, position the regulator to the position. For improved descaling, heat up the iron again fully and press the steam button several times in quick succession. Then wait until the remaining water has evaporated from the soleplate of the iron. Once it has been cleaned, the cleaning warning must be cancelled on the navigation display. To do this, simply press and hold the on/set navigation key for more than 5 seconds, with the iron plugged in. If you do not do this, the cleaning icon will remain lit. 3. anti-calc The "anti-calc" cartridge has been designed to reduce the build-up of scale produced during steam ironing, helping to extend the useful life of your iron. Nevertheless the "anti-calc" cartridge cannot remove all of the scale that is produced naturally over time.
Jan 25, 2011 • Bosch Irons
4helpful
Cant get anti calc cartridges for my steam generator
I had to order mine direct from Breville. If you go to their website and contact them with the model of the iron then they will give you details of price and postage.
Aug 25, 2008 • Irons
11helpful
2answers
Tefal proline express steam generator iron needs de scaling
Make a solution of half water and half white vinegar. Fill up your iron and get it good and hot then let it sit a couple hours. flush out and repeat as necessary. Hope you find this helpful. Please give me a fixya rating If this works for you. It works very well as long as it is not completely filled with scale. Once you have it good and clean By a gallon of bottled water at the market and use that for your Iron and you will never have a scale problem again. I learned how to do this 20 years ago from a 80 year old woman from england. If it is really bad you can up the vinegar concentration but do not go higher than 2 cup to 1.
George
Jul 13, 2008 • Irons
Top Breville Irons Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Breville Iron Expert? Answer questions, earn points and help others
