Plantronics Pulsar 590A Wireless Headset Logo
Dean Posted on Oct 15, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
In recent days my headset (590A) has only been transmitting sound on the right ear via bluetooth connection, when I use the 3.5mm jack (connected to left ear) both ears work. Is there a fix for transmitting via bluetooth to both ears? Thanks in advance, AJ
Anonymous
Level 3:
President:
  • Master 1,015 Answers
  • Posted on Oct 15, 2010
Anonymous
Master
Level 3:
President:
Answers
1015
Questions
0
Helped
451809
Points
3407
Your headset can be used as stereo headphones or a wireless microphone for a bluetooth enabled device like a cell phone or a computer. When you plug the headphones into a device with the 3.5mm jack the headset automatically turns into stereo headphones and disables the microphone(headphone mode). It sounds like whatever device your headset is connected to via bluetooth is using the wireless microphone protocol where sound only comes through the one speaker and the microphone is on(microphone mode). The bluetooth protocol settings of your device may have been changed accidentally. You will need to go into the bluettoth settings of your device you are using with your headset and change the protocol. If it is a cell phone you will need to go into the bluetooth settings in the settings menu. If it is a computer your can adjust the bluetooth settings in the control panel.
You can download the pdf file of your instruction manual for your headset here
I hope this was helpful and let me know if you have any other questions. Thanks for using FixYa
wwlvictoria
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • Plantronics Master 1,001 Answers
  • Posted on Dec 20, 2016
wwlvictoria
Plantronics Master
Level 3:
Renaissance:
Answers
1001
Questions
0
Helped
603623
Points
6027
  • Advanced Technology,The buletooth headphone ensure clear speech within 10 meters and high-fidelity stereo music .
https://www.amazon.com/dp/B01DUA9CA0/ref=twister_B01DUA9C4G?_encoding=UTF8&psc=1
I need connect my blutooth headphone to my hisense 70 inch tv
hello, check if your headset has inbuilt wireless connection technology or not.
If it has, you can easily connect your Bluetooth headset by using your TV's on-screen display. Using your TV remote, locate the accessory menu for your television, then access the Bluetooth settings, and set the pairing mode.
Switch on your headphones and set them to pairing mode. Your headsets will be displayed on your TV as soon as they are detected. You will then have to select your headsets in order to complete the pairing process.
It doesn't have, you need to use a Bluetooth Transmitter. As long as your TV has a headphone jack, then you will be able to connect Bluetooth headphone with TV by using a Bluetooth transmitter. Just make sure you get a Bluetooth transmitter and not a receiver because you are transmitting sound from the TV
Source.
Source. https://www.arkartech.net/blogs/blog/connect-wireless-headphones-to-tv
2answers
Headphone/earphones only left ear plays
Either the plus is not completely inserted (most likely) or a wire is loose or the earphones are damaged.
2answers
Bluetooth headset and headphone jack same time
They're designed to work one at a time. I'm not sure if you could do this with tweaks, but you're going to have to root your phone for that (and you may void your warranty by doing that.)
Feb 02, 2014 • Cell Phones
10helpful
Why wont my logitech boombox go into bluetooth search mode
I had the exact same problem. Boombox flashing blue, but not rapidly flashing blue. I did two things that seemed to fix it:
1: Reset the device by switching it on, then holding both volume up and volume down buttons at the same time for 10 seconds. The blue flashing light will briefly flash quicker to confirm.
2: Switch off the boom box
3: Switch on using the power button and (very important) immediately press and hold the Bluetooth button. The Bluetooth button needed pressing and holding almost instantaniously after the power button for it to work for me. I had to try several times to get it to work.
When you do this successfully, the Bluetooth light starts flashing rapidly and it enters search mode.
I nearly threw my speakers away, now it works and connects fine :)
How to change plantronics voyager pro plus ear plug
The link below for the Plantronics Voyager Pro+ has the information you're longing for. Look under "Mix and Match for Best Fit."
Plantronics Voyager Pro+ User's Guide
Good luck from Headsets Direct!
1helpful
2answers
I am looking to buy a wireless bluetooth stereo headset that is compatable with my Iphone 4... Any suggestions???
I personally own the Jabra Halo, Altec Lansing Backbeat, and the Motorola MotoRokr S9HD
The Jabra Halo is about 50 bucks and goes over the ear with flat speakers.
The Backbeats are about 100, and provide channeling audio via in ear plugs, but not sound isolation.
the Motorola headset is about 100 dollars, but has issues with skipping, especially if the phone is in your back pocket.
1helpful
Bluetooth headset problem
There are two types of profiles that Bluetooth headsets uses. One, it is called the A2DP (Advanced Digital Profile) and second is called the Headset profile (Mono).
The A2DP is used for listening music that's transmitted from the phone to the headset.
The Headset profile is used for calling. But the A2DP can also be used for calling if the phone or the headset support it.
If one of your device (either the phone or the headset) doesn't support it, then that could be the reason why you couldn't hear the sound.
If both devices support A2DP, make sure that your headset is connected to the phone via the A2DP profile.
You need to refer to the phone manual to see if it's supported by your phone and how to connect to it.
Hope I explained it properly. Have a great day!
Jun 22, 2009 • HTC G1
1helpful
Cannont connect Ear Force X3 with my HDMI set up .
Is the problem that you're using a single HDMI cable to connect your Xbox to your TV? If so, this Turtle Beach article should help... ________________________________________
HDMI and Connecting Ear Force Xbox Headphones
The current Microsoft Xbox 360 series of gaming consoles allow the use of HDMI cables for simpler hookup to home theater systems and Hi-Definition televisions (HDTV).
The Xbox 360 Elite (the black one) comes with two additional cables, an HDMI cable and a separate AUDIO cable that provides a pair of RCA jacks (red and white) and an optical digital audio output (S/PDIF Out). With this cable package, you can easily connect any of our X-series headsets and an HDMI-connected television at the same time.
This Xbox 360 HDMI Cable package is available as an extra-cost option from Microsoft: http://www.xbox.com/en-US/hardware/x/xbox360hdmiavcable/
Here's a more in-depth explanation of the Xbox 360 HDMI Cable and how it works: http://support.microsoft.com/kb/937899?sd=xbox
[NOTE 1:] The standard Xbox models do not come equipped with this cable set. The HD cable they have obscures the HDMI connector, so that the two sockets cannot be used at the same time. If you only have this stock HD connector (component video, composite video, stereo analog audio and optical digital audio connectors), then you will not be able to use the HDMI connector at the same time.
In order to use both sockets at the same time (HDMI and A/V) you'll need to purchase the Xbox 360 HDMI Cable package described above.
[NOTE 2:] The current Xbox 360 Elite Holiday Edition (Fall 2009) does not come with the HDMI Cable set.
___________________________________________________________________
Some companies make aftermarket HDMI cables for use with the Xbox 360, but these may not provide the dual RCA jacks that carry the 2- channel analog audio necessary for hookup of the anlog-only Ear Force X-series headsets. If this is what you have, you may need to find another way to connect your Ear Force X-series headset.
The TOSLINK digitally-connected X-series headsets can be always be connected using optical digital "Toslink" connections (and that's the best way to use them!).
The oldest white-and-gray Xbox 360 models DO NOT have an HDMI port. With this particular (obsolete) model, you cannot use HDMI connections, but you can use any of our X-series headsets.
Current Xbox 360 models all have separate HDMI and A/V ports ("sockets") on their back panels.
Here are some suggestions for alternative connection schemes:
XBOX 360 AUDIO PLAYS THROUGH TELEVISION SET:
For X4 and X41: Your best bet would be to connect the Xbox optical digital audio out to the X4 transmitter's optical digital input. Then connect the X4 optical digital output to the optical digital audio input on your HDTV or home theater amplifier.
[NOTE:] Some HDTV systems have an optical digital audio output that will not transmit Dolby Digital/DTS encoded digital audio, only stereo PCM audio will be passed. In this case, you must connect as above.
For X2, X3 and X31: You can use the Headphones jack or the Audio Out jacks on your TV to connect to the Audio In jack on the Transmitter.
For X1 and X11: You can use the Headphones jack or the Audio Out jacks on your TV (if available) to connect to the headset's analog Audio Input.
NOTE: Please make sure your TV has Audio Out jacks. Some TV's only have Audio In jacks.
Audio In jacks only accept incoming audio signal; they do not send audio signal out. If no audio signal is being sent to the headset, no sound will play from the headset.
You may need to purchase a suitable adapter cable in order to connect the TV audio output(s) to the Ear Force X-series headset's transmitter or Audio Input plug.
- Connect the HDMI cable so that the Xbox 360 plays its audio through the TV.
- For X1, adjust the Dashboard > Settings > System > Voice in the Xbox 360 so that the talkback and game sounds are played together (Play Through Speakers). - For X3, X31, X4 and X41, you should set this to Play Through Headset.
XBOX 360 AUDIO PLAYS THROUGH HOME THEATER RECEIVER (except X4 and X41): This is exactly the same as the above, except that you will use the receiver's Headphones output jack to connect to the Audio In on the Ear Force Xbox-compatible headset's Transmitter (X2, X3, X31) or the green Audio Input plug (X1).
- You may need to obtain a shielded audio cable with 1/4" stereo phone plug to 1/8" stereo mini-phone plug ends. The 1/4" phone plug goes to the receiver's Headphones jack, while the 1/8" mini-phone plug goes to the Audio In on the Ear Force Transmit- ter (X2, X3, X31) or Audio Input plug (X1).
- Adjust the Dashboard > Personal Settings in the Xbox 360 so that the talkback and game sounds are played together (Play Through Both). For X3 and X31, you may also set this to Play Through Headset.
Sound louder in right Ear!
If its not something simple like a balance control in your player or a bad earbud (try a different set of earbuds w/a 3.5mm jack).
Then try this:
Theres no mention of a balance function in my Itech manual. It could be a loose solder connection on the board. Thats a common thing to happen with and circuit board mounted hardware that goes out of the unit. I.e. to your ears. Ever so slightly move the earbud jack back and forth, up and down and see if you hear static or the volumes change. If so theres 2 things to try....
First try some contact cleaner, spray it on the male jack and plug it in and out of the unit a few times for a simple try at it.
If it still has imbalance then take the cover off, for the jack side of the unit, resolder the little pins of the inside jack to the board (on the backside of the board). Or find someone that can. These units are worth a few bucks to repair IMO.
Hope this Helps
Using headset jack - unit always transmits
Try plugging in headset BEFORE turning on radio. You should see the word VOX (not iVOX) on your display. At least this is what works for me.
Top Plantronics Radio Communications Experts
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
