If you open the kick plate, you'll see the pan below the motor and check for leaks. The leaks will trigger the sensor to pump water out. Once you dry out the pan, the pump motor will stop and you should be able to reset the program.
I had a tech come out because my viking dishwasher would not turn off he said the main motor circulation is leaking water and needs to be replaced
