If your wallplate is hot, that is a sign of trouble, and possible electrical fire. That dimmer is not made for the load, or it is going bad.
Turn off the dimmer immediately. Do not use the dimmer at all. Replace with a wall switch until you have the correct dimmer.
Each dimmer is rated for Watts. Ordinary electrical switch is rated by amps. Ordinary 15 Amp electrical switch can handle up to 1400 Watts. This means 14 - 100 watt bulbs.
Dimmers are usually not rated for 1400 Watts. They have 500-600 Watt rating. Look at the side of your dimmer for Wattage information that is usually printed on dimmer.
Heavier-duty dimmers cost more and can carry more wattage. Some dimmers carry up to 1800 watts. These kinds of dimmers have aluminum heat sink visible right on the face of dimmer.
In any case, your dimmer is an electrical fire hazard and should be replaced. Add up total wattage of your lights, and read new dimmer package when buying.
Up-vote if this information is helpful. Thanks for the feedback.
