Clear error code 507 on blackberry 7290
error code 507 on my phone. Havent tried much as I don't know what to try apart from the obvious take out the battery for a while and re insert!
i tried this but it did work.. i can't even turn it off if you press and hold the power button. I need to remove the battery but when it loads up it shows thesame message 507 i tried this but it did work.. i can't even turn it off if you press and hold the power button. I need to remove the battery but when it loads up it shows thesame message 507
Error 507 try to load O/S however asks for devise password enter (Blind as still has 507 error message) cann not get ant furtherError 507 try to load O/S however asks for devise password enter (Blind as still has 507 error message) cann not get ant further
AnonymousApr 20, 2009
esce la solita schermata bianca è un mese che non lo accendo e pure esce error 507 reset ecc..aiutooooooooooooo come faccioooooooooo
You can't post conmments that contain an email address.
Basically this means that there is an error with your BB operating system or software, you will need to reload you app's though apploader through your desktop manager.
Pulling the battery out while the device is on is worth a try before you reload the os, this is called a hard reset and fixes 80% of BB issues.
My computer/C:/program files/common files/ Research In Motion/AppLoader and then get rid of Vendor file... go to Desktop Manager and reload the os... it worked for me... if you want to be on the safe side i suppose you could copy and paste vendor file somewhere else or just move it out of the folder...
well you have done great so far. Error 507 means that JL-CMDER has done its job and wiped all applications off your phone. So just do the next step by connecting it to your 4.7 Blackberry Desktop and select App Loader and install the OS and Applications on the phone. Please write again if you need more help
507 means no operating system found. You will need to reload the OS. Device may require a clean wipe and re-install of the OS. The 507 error means that the operating system is no longer on the device. Any data on the device is gone, too. You won't be able to retrieve it unless you have a backup.
You will need to reload the operating system on to the device. You will need the Desktop Manager program, along with the BlackBerry handheld device software.
And you can follow these instructions for upgrading your operating system: http://crackberry.com/blackberry-101-how... If I could be of further assistance, let me know. Otherwise, please rate this.Thanks, Joe
Practically speaking i spent 3 hours looking for your solution but nothing much even the BB intelectuals failed .Try these steps out it may resolve the issue and lets hope for the best .
This error : 373 : Device Error means that the Timers are corroupted
1. Remove the battery for at least 5 minute.
2. Make sure u have working SIM card, other wise remove the old SIM.
3.You should receive an Hour glass spinning. Give a few minutes, after that u will see a 507 message on the bb screen, (which means there is no app loaded on the bb)
4.If this dosent work
Use application loader to wipe handheld clean and reinstall base software but do backup your data
I have problems whit my BlackBerry 7290. Wen starting it is showing "error 507". pls help me how unlock it. post solution for me here.. thank you for help me
i tried pulling the battery ,it did not work .is there another solution to fix this 507 error code.?
