had a quick look online and found this is a museum piece. http://www.flashlightmuseum.com/Eveready-Flashlight-FAB4DCM-Red-Black-Sea-Beam-Waterproof-Lantern-6V-2003
Called a Dolphin torch, I remember these from the '80s and had to replace the batteries too often to ever want to do it again.
The front unlocks by rotating 1/4 turn. The batteries are a 6V sealed lead acid cell and now cost more than a new modern torch with a Li-ion cell. You will need a 6V charger if the battery can be recharged and unlikely if its old and discharged for long time.
you can google your question for answers.try it
About 7,790,000 results (0.50 seconds)
A big hint if you can't or wont google your question.
That depends on the species. There are nearly forty species of dolphins, ranging from about 1.2 m and 40 kg to 9.5 m and 10 tonnes. See http://en.wikipedia.org/wiki/Dolphin.
you have the option of using may different browsers like dolphin and skyfire, they all work differently for different web sites. if one dosent work use another
Yes there is a cap. I had the same problem most likely the battery inside has corroded and leaked fusing the cap shut, contact MagLite at www.maglite.com if there were either Duracell, Eveready or Ray-O-Vac batteries in there they will replace it for free under warranty.
