Craig 731398407019 Portable DVD Player Logo
Posted on Oct 14, 2010
Just bought a craig portable dvd player with lcd tv. dvd plays movies fine but cant figure out how to get a signal for tv. WILL NOT PICK UP OVER THE AIR SIGNAL
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 25, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1199
Points
5
All you need is a good pair of rabbit ears. The one that has a cable type connection that will screw on the antenna.
Anonymous
Level 1:
New Friend:
  • Posted on Oct 26, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1199
Points
I can't get an air signal from my recently purchased lcd tv. dvd plays good. Help.
  • Gaily350 Jan 08, 2011
    So how can I get the tv signal.
Craig 7 inch lcd tv with dvd player is sold as DIGITAL meaning it will pick up digital tv signals with a tuner or antenna like my old tv at home with a converter; right?\r\nCan get no signal on tv...
The word "Digital" means, that device have digital processor circuit inside, which uses only for signal processing. Not mean that it will pickup digital signals. You did misunderstand that word. That's all.
http://electrotechnician.blogspot.com/
Wont lode movies
Please check weather the DVD which your inserted i supported by the player.?
If someother movies plays then the problem is with the DVD which your inserted.The DVD might have not burnt in correct formatt.
Thanx
2answers
There is no colour on the movie
Make sure you have the cables hook up right. If you are running component mode it takes three for video blue red and white ends. If you are running composite it takes red, white, and yellow.
2helpful
I cant get the DVD's to start playing on Proscan Tv
That is one problem with buying open box or display models. Ive learned the hardway myself. I'm guessing if this is the case you did not get a warranty with the item either.
The only thing I can suggest is that you buy a replacement remote from the manufactor. Seems proscan products are made by RCA.
This is a link you will be able to email them and tell them you need a remote give them the make and model of the TV, to get a price.
http://tv.rca.com/en-us/ContactUs.html
Good luck, and thank you for choosing Fixya!
HDMI->DVI cable won't work
Are you using a HDMI to DVI cable or are you using a HDMI to DVI adapter? Sometimes, though not on all products you have to go into the menu and select which out put your using for each source and whats going through it. You might need to go into your dvd player menu and tell it not to try to run audio through the cable. That way it's not trying to force a signal through the cable that cant be accepted by the TV. That might possible solve your problem for the DVD player. Let me know if it works
Have a Great day
Panasonic DVD-LS855 wont play to LCD TV
Did you turn on the input of the tv to receive 'external' input.? Did you plug the DVD into the right input?
Cant play movies
If your DVD player is less then a year old, still under manufacturers warranty. I would suggest to call the manufacturers to get the name of an authorized dealer near you to fix it.
2answers
Movie playing black and white
the problem sounds like its with the s video connection, try using the composite video input
4answers
Craig portable dvd player CTFT701
My screen would flicker when you tilted it back and forth. Sometimes it would cut out and moving it would make it come back on. I took the battery off and opened the screen from the front(2 screws in hinge & 2 screws under rubber plugs). There is a ribbon plug inside. Mine looked kinked in one spot so I just repositioned it so the kink was in another spot. Everything worked fine after that. Hope this helps.
Top Craig Televison & Video Experts
Paul Bade
 Grubhead
Grubhead
john h
Are you a Craig Televison and Video Expert? Answer questions, earn points and help others
