Question about Falcon Cycling
I had to take off the rear weel of my falcon apache mountain bike to get it in my car o travel from my grandparens home to mine but i cant get the back weel gear arm back on. how do i do this??
  • 843 Answers
By the "gear arm" I assume you mean that part of the rear derailer that the chain zig-zags through. This arm moves in two ways. It moves in and out (toward the wheel and away) as you move the shift lever - which is how it changes gears, by moving the chain onto different sprockets (gears). It also moves forward and back (toward the front and back of the bike) under spring pressure. This forward and back motion is necessary to take up the slack in the chain when you are using the smaller sprockets (the smaller the sprocket, the "higher" the gear). When the wheel has been removed, this arm moves forward (under spring pressure) as far as it can to take up all of the slack in the chain. All you have to do is grasp this lever and pull it toward the back of the bike, allowing the lever and the chain to pass behind the sprockets (gears) as you pull the wheel back into it's position. You can safely pull this arm forward and back at any time without doing any damage. One more tip-- I find it a little easier if you first put the shift lever in a "middle" gear position. Then when you pull the wheel into place, you should aim to put the chain on a middle sprocket. You don't have to hit the exact correct sprocket as you can simply lift the rear wheel and turn the pedals forward (after installing the wheel) and the chain will move to the correct sprocket corresponding to the setting on the shift lever.
Good luck! Please vote if you found this helpful. Al K
Posted on Oct 14, 2010
  • Al Kupchella
    Al Kupchella Oct 14, 2010
    Steffan,
    I just re-read your question, and I realize that I assumed you were having trouble getting the wheel on because the gear-arm was in the way. But perhaps you actually removed the derailler in addition to the wheel? As you probably realize now, that was a mistake! And in that case I hope that my description of how the derailler moves will give you some idea of how to re-install it.
SOURCE:
I would like to know the size of the frame on the Mongoose 29in Torment Men's mountain Bike
18" Frame
Bicycles in Brand:Mongoose, Gender:Men, Wheel Size:29" ' eBay
https://www.ebay.com > Sporting Goods > Cycling Equipment > BicyclesResults 1 - 48 of 80 - 29" Mongoose Status 2.6 Men's Mountain Bike, 18-Inch frame, White ... The Mongoose 29in torment mountain bike will provide for hours of ...
Mongoose 29in Torment Mountain Bike - Kmart
www.kmart.com/mongoose-29in-torment-mountain-bike/p-080W004611130001P
Rating: 5 - ‎1 review
Oct 27, 2012 - Enjoy Fresh Air with this Rugged Mongoose Torment Bike 21 Speed The Mongoose 29in torment mountain bike will provide for hours of safe riding in th... ... Wheel Size: 29 in. ... Gender: Male ... It's rare to find an aluminum frame at this price point. As I wheeeled it up to the counter, many people stopped to ...
Mongoose 29" Front and Rear Disc Brake 21 Speed Mens Torment ...
https://www.amazon.com/Mongoose-Front-Brake-Torment-Mountain/.../B075CQPV5... Rating: 4.2 - ‎3 reviews
... and Rear Disc Brake 21 Speed Mens Torment HD Mountain Bike : Sports & Outdoors. ... power; Alloy frame with formed tubes and internal cable routing for clean look .... Product Dimensions: 58 x 10.2 x 33.8 inches ; 52.3 pounds; Shipping ...
Mongoose 29in Torment Mountain Bike - Sears
www.sears.com/search=mongoose%2029in%20torment%20mountain%20bike Mongoose Torment 29" Mountain Bike · 2.0. (1)Sold by Sears. add to comparecompare now. Mongoose 29" 21Speed Mens Torment HD Mountain Bike.
Mongoose Torment 29" Mountain Bike - Sears
www.sears.com/mongoose-29in-torment-mountain-bike/p-00654966000P Rating: 2 - ‎1 review
Feb 23, 2014 - Mongoose Mongoose Torment 29" Mountain Bike 1 ... A durable aluminum frame handles rugged trails and roads; Front and rear brakes with easy-to-reach handles for safe stopping ... Wheel Size: 29 in. ... Gender: Male ...
Bicycles in Brand Mongoose Gender Men Wheel Size 29 eBay
May 29, 2018 | Mongoose Cycling
Why does my TVS Apache 150 overheat?
Hi, Hasan and the usual suspects are:
1. Engine oil level and SAE weight are too low or not circulating.
2. Insufficient or blocked air flow over the engine.
3. Heavy combustion chamber carbon deposits.
4. Ignition timing retarded due to faulty MAP, CKP, or CMP sensor.
5. Carburetor jetted too lean.
6. Leaking intake or exhaust valve.
7. Water coolant old or low change every two years.
8. Water pump failure.
9. Radiator clogged, cap loose or malfunctioning.
10. Radiator fans not coming on.
11. Clutch slipping, brakes dragging, heavy load, towing a trailer etc.
12. Idling too long without moving.
13. For constant hot weather temperatures, mountain, or desert riding conditions consider adding an oil cooler and or cylinder head cooler.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
http://www.complaintboard.in/complaints-reviews/tvs-apache-rtr-180-l57056.html
http://www.motorcycleforum.com/129-first-bike-new-rider/192586-tvs-apache-rtr-engine-overheating-along-increased-idling-rpm.html
TVS Apache 150 2011 service manual DOWNLOAD FREE FULLMANUALS COM
http://www.tvsmotor.co.id/images/catalogue/docs/apache.pdf
https://www.tvsmotor.com/manual-download.asp
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jan 02, 2017 | 2010 TVS Apache 150
Just bought a used mountain bike...chain keeps falling off
1) Replace the chain.
2) Adjust the travel of the front and rear derailer.
3) Make sure the rear wheel is set properly in the rear fork.
May 07, 2011 | Bike Extreme Lite Youth Shoulder Pad
I am trying to fix a Huffy Blackwater bicycle (15 speed). The rear derailleur is missing. Can I use a 6 speed derailleur from a Next bike? Can I disable the indexing of the Huffy (Falcon) shifter? Thanks
You can use the 6 speed rear derailleur with no problems. The 5-spd shifter does not need to be disabled, as it will work just fine.
The shifter controls the rear derailleur, telling it how far to move. The rear derailluer just follows what is dictated, so there is no real difference mechanically between the 5spd and 6spd derailleurs, only in the shifter.
If you wanted to make the bike 6spd, you would have to change the shifter and gears along with the derailleur.
Dec 21, 2010 | Huffy Blackwater Men's 26-Inch Mountain...
Need to know how much air to put in rear suspension bike ride hard
Until it is hard except on a hot day because the heat will cause it to expand and pop like mine did.
Jul 29, 2010 | kawasaki Full Suspension Mountain Bike Men
X-cross mountain biker-brakes
this is something you need to take up with your local bike shop
Apr 12, 2009 | Mountain Sram Pg 950 11-32 Cassette...
Cycling Logo
205 people viewed this question
Top Falcon Cycling Experts
Marvin
Marvin
Michial Gueffroy
John Egan
John Egan
Are you a Falcon Cycling Expert? Answer questions, earn points and help others
