If UPS is displaying "Site Fault", it is doing its job correctly. You need to check the wall receptacle. Probably hot and neutral reversed, or the neutral and ground are reversed, by whom ever installed the wall receptacle.
Hi, here is the documentation page for the 9120 where you can find the manual: http://powerquality.eaton.com/Products-services/legacy/9120-info.asp You can also contact customer support 800 356 5737 or [email protected]. You may recognize the product as the Powerware 9120 but Powerware was bought by Eaton a few years ago. The customer support team is most ex Powerware and are familiar with the 9120.
Take
wires out of plug and the wire from the connecter box of machine. With multi
tester test earth to live and earth to neutral. If there is a short circuit it
will show on which wire it is. Next disconnect live and neutral wires from
motor and run test on all wires. If no short the motor is faulty and test the
motor connectors. If the short is not found the motor is not the problem but
the control system. Disconnect all wires from controls and test everything
isolated and individually.
