Question about Polycom SoundStation IP 6000 (220015600001) Audio Conference
The Soundstation IP 6000 does not start it says: " Could not contact boot server, using existing configuration" an then it shows " Error loading 0004f2e427de.cfg " Im using Trixbox Pro and have other IP6000 that works perfectly what can i do, already try to reboot and restart and nothing, what can i do?
3 Suggested Answers
SOURCE:
SOURCE: Trying to setup Polycom IP6000
What system are you installing it on?
Posted on Sep 01, 2010
SOURCE: i have polycom SoindPoint 301
1st. Get the IP address of the phone. and type that into browser.
*- default user: Polycom / password: 456
*- Under menu SIP, type in your voip provider
*-Under menu LINES type in user info and "secret" should be your password.
Make sure your ports are open (SIP is usually 5060) you can change it in that same config screen.
Posted on May 04, 2011
How to change the ip address of a hp jetdirect 170X
The manual is located here, and it recommends the following procedure, which starts on page 18.
Connect the Jetdirect box to the printer and the network and power on.
Press the Test button on the back of the Jetdirect box to print a configuration page.
The configuration page should show the IP address of the Jetdirect box.
If this is an IP address in the normal range of your network, ie the first three numbers of the Jetdirect box's IP address and your computer's IP address is the same (such as 192.168.0.) then simply type the IP address into your computers internet browser and you can reach the configuration page. The steps on page 58 detail the user interface for the web login.
If the Jetdirect box does not get an IP address withing 2 minutes of it booting up, it assigns itself an IP address of 192.0.0.192, and you can connect to it over the network if you change your own network settings to 192.0.0. and a number from 1-254 (but not 192).
May 04, 2011 | HP Jetdirect 170x Print Server
I have polycom SoindPoint 301 and i would like to use as SIP to one of the VoIP providers. I dont have asterisk in my network and i would like to connect it directly to the VoIP provider. So there is no...
Mar 28, 2011 | Polycom SOUNDPOINT IP 301 SIP
Coult not using boot server error loading 0004f217b421.cfg
This occurs when the phone is set up to load it's configuration file from a ftp or tftp server and it cannot find the file or server location. If the phone is supposed to do this, please check that the ftp or tftp service is running on the specified server. The server name or ip is specified in the setup of the phone, available when the phone is first booting up. The default username is 'Polycom' and password is '456'. If you DO NOT want your phone to get it's configuration from a network server, enter the setup area and remove the server name or IP address from the appropriate section.
Feb 04, 2011 | Polycom SoundPoint 330 IP Phone
We tried to put factory default in Polycom IP 331 SIP Phone.It is booting continuously and it shows the following error while booting."Error loading 0004f2329caf. cfg". All the other booting...
I answered this question for another user:
http://www.fixya.com/support/t8134583-coult_not_using_boot_server_error
Jan 04, 2011 | Polycom SoundPoint IP 331 IP Phone
Oops this link appears to be broken dns error - cannot find server windows 7 explorer 8
The error refers to the Domain Name Server (DNS) that your system uses is unable to translate the Uniform Resource Locator (URL, web address either Typed in the address line or linked using a hyper-link, favorite or default home page) (In english, the translation of a web address link www.google.com to the Internet Protocol (IP) address that computers actually use to show the page)
Possible causes:
  1. The URL is wrong. (Typed wrong, link no longer active, link changed)
  2. The DNS server listed for your ISP configuration is not working.
  3. The web site is offline.
  4. The DNS server settings for your internet configuration are wrong.
Possible resolutions:
  1. Try a different Web Address, see if it works
  2. Restart (Completely power off your Cable/DSL modem and then do the same with your router)
  3. Check you IP address configuration settings and ensure that auto-assign DNS is selected (Default setting)
  4. Boot to safe mode with networking, see if you can get online that way.
Dec 21, 2009 | Computers & Internet
I has polycom soundpoint ip33, while booting its giving error " error loading 0004f220429c.cfg" and its not booting at all.pls guide me how to fix this problem.
Can you pls check the configuration file on the tftp server
some wrong information is there
pls compare with any other ip phone
Oct 30, 2009 | Polycom SoundPoint 330 IP Phone
Error loading 0004f220429c.cfg
This means the phone cannot find its <mac>.cfg file on the boot server, and does not have one loaded in its own flash memory.
You will need to configure a boot server to host the SIP software, BootROM, and all the config files (these are included in with the SIP software).
You can download these from Polycom's product support page:
http://www.polycom.com/support/voice/soundpoint_ip/soundpoint_ip330_320.html
Aug 18, 2009 | Polycom SoundPoint 330 IP Phone
I am unable to push the configuration files into polycom soundpoint ip 330 through tftpd
This means the phone's SIP application has been erased. You will need to download the SIP app and BootROM from the Polycom support page, host the files on a boot server, and then point the phone to this server from the server menu so the phone will reboot and download the files.
Aug 28, 2008 | Polycom SoundPoint 330 IP Phone
Polycom SoundStation IP 6000 (220015600001) Audio Conference Logo
479 people viewed this question
Top Polycom Lands Phones Experts
pankaj rautela
pankaj rautela
Are you a Polycom Lands Phone Expert? Answer questions, earn points and help others
