Frigidaire FEF366DC Electric Kitchen Range Logo
Anonymous Posted on Oct 13, 2010
I have a Frigidaire electric stove & can't find the fuses. Please help.
  • Anonymous Oct 15, 2010
    thanks for your input,I'll check
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 351 Answers
  • Posted on Oct 13, 2010
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
351
Questions
0
Helped
60617
Points
957
Hi not to be short bot there are no fuses. what the rang doing or not doing? jim
  • 2 more comments
  • Anonymous Oct 14, 2010
    The Plug on top has stopped working
    when you say plug do you mean burners or a recital how old is rang? jim
    its the receptical, its only about 3 yrs old
    hi you know there may be a reset on that rang or you can turn the receptacle on and off by the clock . i am not being much help to you as i don't do a lot service on frigidear. i would look around the plug for a button or reset or behind the rang i am sorry i don't know. someone else on here may know
4answers
Where are the fuses located in a frigidare stove
Good Afternoon Friend, this is Z. Thank you for your post!
I understand you are seeking the fuses location in your Frigidaire range. May I please have your model number? You can typically locate the serial tag (which lists your model number) in the storage drawer, on the right side. Please describe what your appliance is doing so that I can assist you better in pinpointing the problem before you take this step. Thanks!
Why doesn't the outlet on the stove top work
disconnect power remove back panel insect outlet wires check black wire for 110 volts check 15 amp fuse or replace Cheers
Frigidaire crown series electric stove just delivered.
Hello - I would first suggest confirming that the range is plug to the proper voltage (120/240 Volts 40/50 Amp). Was there anything located behind the range before pushing it back? From what you have described it sounds like the control board will need diagnosing. Contact a professional to move forward accurately.
Frigidaire stove(smooth top -electric) all of sudden started to beep' constantly w/F1 flashing.Tried to reset - unsuccessful. Unplugged & waited an hour to plug back in & still beeping...
The F1 error code means a button on the touchpad is stuck,usually pushing clear/off will clear it. Since you have done that and it returns the touchpad needs to be replaced
Gene
We have a 40amp hot wired stove but now we just bought a frigidaire fef366dce with a 50amp. Will the new stove work well if hot wired to the 40amp
The new stove may work but you may also blow the breaker/ fuse which ever you have... make sure to leave the 40 amp fuses or breaker in the box as the wiring will not be heavy enough to support a larger amp. fuse or breaker... that will start a fire!
You may find that you just cannot run all of the burners and the oven or broiler at the same time.
heatman101
1984 stove, fuses located on the top of stove/ 30amp keeps blowin
It sounds like the element has a short in it. unplug the range, and take the element out and inspect if for burn marks. check the wires going to the element to make sure they have not shorted.
Our frigidaire flat-top electric stove stopped working
Sound like you make have a loose neutral on the cord where it attaches to the range or in the electrical receptacle where it plugs in, you can check the cord by pulling the range out, remove the small access cover to the cord connection area, after you have unplugged it and just tightened all the nuts to all connections on the cord. I advise an electrician to check the receptacle. I hope this has helped you. Have a great new year.
Frigidaire deluxe electric stove Model# RDG3-35S
The pipe is a vent pipe it is normal and th fuse is behind the back panel right behind the pots and pan shelf beside the stove pull the shelf out and replace the fuse with a 15 amp
Top Frigidaire Kitchen Ranges Experts
Paul Carew
ZJ Limited
ZJ Limited
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
