Question about Samsung SGH-R225m Phone
R225M earpiece problem
When I attach an earphone (bud or other), the switch on the earphone does nothing, does not enable me to answer a call. If I press the "accept" button while the earphone is plugged in, it causes the incoming call to disconnect. I've never used this feature before (have had the phone for two years). Is this a setup issue or is there a problem with the earphone output of the phone?
Thanks,
John
    Genius:
  • Samsung Master
  • 1,691 Answers
If you bought a clone or non original earphone it can do that on your phone. Some of the PDA models are also very critical to the circuit wiring for the earphone, the switch, and the impedance.
If you are using the original earphone, and have this problem, it may be that there is a defect in the wiring, or the phone has a defect in its circuitry that works with the earphone.
Jerry G.
Posted on Aug 07, 2008
SOURCE:
I am having trouble connecting headset to cell phone. I have tried all instructions on how to connect headset to phone. Nothing works.
If this is a bluetooth connection ,make sure its switched on in the phone and put a jack lead without buds into earphone piece on phone.
Jan 13, 2018 | Radio Communications
I don't know my Smokin buds earphones keep buzzing on my Nokia N97
Most likely the 3.5mm jack is damaged or the earpiece receiver itself. Try it on different devices. If it only happen on your Nokia, the frequency may not be calibrated easily
Oct 02, 2012 | Skull Candy Smokin' Buds Headphones
Louder in one ear than the other
There is a possibility that your earphones need cleaning. Take off the tips and gently brush the metallic mesh with some cloth. Then dip each earpiece into drop of alcohol (you need to dip mesh only, not the whole earpiece). Then wipe it clean with cotton bud or something similar. Next, dip your earpieces the same way into drop of hydrogen peroxide and leave them there for few minutes. After that, wipe them again.
I used this method on my ie8 and it really helped.
Feb 21, 2012 | Sennheiser IE8 Headphones
What can I do to fix a cable issue in my headphone? The right side doesn't work unless I move around the wire attached to the headphone.
Hi, what makes oneofthe earphones not to work,is because the wire inside the right side of the earphone hascut and will need to soldered back to it's position.
Open the right side of the earphone,and use a soldering iron and a lead to put back the wire properly.
after put back the wire,problem solved.
Thanks for using fixya..
Oct 27, 2010 | Skull Candy Ink'd Stereo Ear Bud...
Left ear bud lost all sound- no cord damage-only 5 months old...is it worth getting fixed by professional or is there something I can do to fix it ? H
The cords are sealed into the earphone. You can take a multimeter and test the continutity of the either earpieces, once you are convinced that the left side is faulty, first of all use a small thin needle as the probe, use your multimeter in the continuity range, holding one end of the meter probe to the jack , inset the pin like an ijection into the wires to obtain the connection, it there is no connection out of the headphone jack, I think you can replace with a new one to be soldered. If not proceed to the earpiece to confirm, then open the sealed unit and be lucky if the earpiece is not damaged but only the wires. Good Day
Jul 07, 2010 | AKG K 321 cloud white Headphones
Err 01communications between the camera and lens is faulty. Clean the lens contacts.
Some people have reported that this error comes up when they have changed a lens on the camera, If the previous lens was IS enabled and was switched on when the old lens was attached, re attach the previous lens and switch off before attaching the new lens.
If this does not work, clean the contacts with a cotton bud dipped in methylated spirits. Hold the lens above you when doing this so nothing falls into the lens.
Jul 11, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
How do i connect headset to panasonic kx-t7433
Just connect the pre existing speaker or earpiece through a newly installed E.P. socket.Whenever headset is connected to the E.P. socket, internal speaker will be disabled and external will be enabled. Same you have to do in the case of mic.Some more details are given below.
1.E.P. Socket = Earphone Socket ( With Series Switch, A SPDT switch is already attached to the inner side of the socket, whenever an E.P. Pin / Plug is inserted into the socket, It changes the position of the SPDT switch).
2.The inner speaker / earpiece / mic should be connected through the N/C ( Normally Connected ) Contact of the socket.
Aug 18, 2008 | Panasonic Lands Phones
Earpiece stopped working
That is at your local dealer... LG will give you 1year warranty.. Anyways it seems to be a problem with the earphones.. Did you try a different set of earphones?
Mar 18, 2008 | LG CHOCOLATE VX8500 Cellular Phone
Cant hear out of one side of earpiece
have you tried using differnt earphones? if the problem is still the same with different earphones then it's the ipod itself that has a problem, you'll have to get it fixed.
Feb 24, 2008 | Apple iPod nano
Earpiece on phone has no sound coming out. can talk but can't hear
i have that problem too. using the speakerphone will help but calls arent clear..
Nov 01, 2007 | Motorola Mobility i870 Cellular Phone
Samsung SGH-R225m Phone Logo
53 people viewed this question
Top Samsung Lands Phones Experts
Don Hart
Jose Ma DM.
Jose Ma DM.
Maher Kareem
Level 1 Expert
Are you a Samsung Lands Phone Expert? Answer questions, earn points and help others
